[mapserver-users] raster layer problem in mapfile
Balázs Bámer bamerbalazs at gmail.com
Thu Feb 19 14:41:53 EST 2009
Hi All,
I try to make a simple classified raster mapfile. However, Mapserver
5.2.1 always ends up with this in log: msWMSLoadGetMapParams(): WMS
server error. Invalid layer(s) given in the LAYERS parameter.
OS is Ubuntu Linux 8.10, Mapserver was compiled with ./configure
--with-oci --with-oraclespatial=/usr/local/instantclient_11_1
--with-proj --with-threads --with-gdal --with-ogr --with-jpeg
--with-png=/usr/lib --with-php=/usr/include/php5
The jpg file is greyscale, and there is also a vakterkep.wld world
file. Paths should be OK because it was derived from an earlier one
using shapefiles. Server response is
<ServiceExceptionReport version="1.1.1">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in
</ServiceException>
</ServiceExceptionReport>
What is the problem?
Thank you in advance, best regards: Balázs Bámer
mapfile contents:
# Start of GMAP map file
MAP
NAME KATEGORIAS
STATUS ON
SIZE 650 500
# xmin ymin xmax ymax?
EXTENT 420000 40000 950000 370000
UNITS METERS
PROJECTION
  "init=epsg:23700"
END
SHAPEPATH "."
IMAGECOLOR 200 200 200
DEBUG 5
CONFIG "MS_ERRORFILE" "/var/log/mapserver/error.txt"
CONFIG "ON_MISSING_DATA" "LOG"
# Start of web interface definition
WEB
  MINSCALE 10000
  MAXSCALE 1000000
  IMAGEPATH "/tmp"
  IMAGEURL "/tmp"
  LOG "/var/log/mapserver/ms_error.txt"
  METADATA
     "wms_title" "kategorias proba"
    "wms_onlineresource" "http://att-it.homelinux.net:22080/cgi-bin/kategorias"
  END
END
# Start of legend
LEGEND
  LABEL
    TYPE BITMAP
    SIZE MEDIUM
    COLOR 0 0 89
  END
  STATUS ON
END
# Start of scalebar
SCALEBAR
  IMAGECOLOR 255 255 255
  LABEL
    COLOR 0 0 0
    SIZE SMALL
  END
  SIZE 150 5
  COLOR 255 255 255
  BACKGROUNDCOLOR 0 0 0
  OUTLINECOLOR 0 0 0
  UNITS meters
  INTERVALS 5
  STATUS ON
END
QUERYMAP
  STYLE HILITE
  COLOR 255 0 0
END
# Start of layer definitions
LAYER
  NAME kategorias
  METADATA
    "DESCRIPTION" "kategorias"
    "wms_title" "kategorias"
#    "wms_srs" "EPSG:23700" nem kell orokli terkepet
    "ows_include_items" "all"
  END
  PROJECTION
    "init=epsg:23700"
  END
  TYPE RASTER
  STATUS ON
  DATA "vakterkep.jpg"
  CLASS
    EXPRESSION ([pixel]<64)
    STYLE
      COLOR 0 32 64
    END
  END
  CLASS
    EXPRESSION ([pixel]>=64 and [pixel]<128)
    STYLE
      COLOR 0 64 128
    END
  END
  CLASS
    EXPRESSION ([pixel]>=128 and [pixel]<192)
    STYLE
      COLOR 0 96 192
    END
  END
  CLASS
    EXPRESSION ([pixel]>=192)
    STYLE
      COLOR 0 128 255
    END
  END
END # layer
END # Map File
