[mapserver-users] Edit mode in mapserver
Alexandre Dube
adube at mapgears.com
Fri Feb 20 15:21:43 EST 2009
Sorry,
I should have written : it's not possible to use WFS in transactional
mode with MapServer.
Sure, you can write your own script with mapscript, but I think using
the OpenLayers UI, with the drawFeature control, it's easy and a common
practice.
Regards,
Alexandre
Blaise wrote:
> Hi there,
> Hopefully, it IS possible to edit features with MapServer / MapScript. You
> have to write your own functions. It works great.
> Regards
> Blaise
> On Friday 20 February 2009 21:04, Alexandre Dube wrote:
>> Hi Rohan,
>> It is not possible to "edit" features with MapServer. You might want
>> to take a look at one of theses projects that can : GeoServer, TinyOWS,
>> FeatureServer.
>> In a small demo I wrote, I use MapServer as my WMS server to render
>> images and TinyOWS as my WFS server to return GML and to do my
>> transactional stuff ( insert/update/delete ) and finally OpenLayers as
>> my client UI. Both MapServer and TinyOWS read the "road" data from a
>> PostGIS database ( required with TinyOWS ). See the demo below (1).
>> Hope this gives you some clues/ideas for your project.
>> Regards,
>> Alexandre
>> (1) http://dev4.mapgears.com/bdga/bdgaWFS-T.html
>> (2)
>> http://dev.openlayers.org/sandbox/topp/wfs/examples/wfs-protocol-transactio
>> ns.html
>> rohan phatak wrote:
>>> Hello Friends,
>>> I am using Mapserver Application Gmap in which .map file is using. I
>>> am trying to develop "Information System" & I want to publish these
>>> map to other computers & i want to give 'edit' mode for user means if
>>> user see any new feature then he can insert point/line/polygon data in
>>> it with attribute information. ( the relationship is like Server-Client)
>>> So how to do this??
>>> 1. Is PHP/ mapscript will useful Or
>>> 2. Is there any inbuilt application to do these??
>>> at a time only one user can use edit mode.
>>> thanks a lot !!
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alexandre Dubé
Mapgears
www.mapgears.com
