[mapserver-users] MSCompanion: A new Mapfile WYSWYG editor is finally available for you
enri enri at 163.com
Sat Feb 21 12:02:39 EST 2009
Hi, James,
when you run MSCompanion the first time, it will create a config file according to your settings in the folder of the EXE file as I expect, which named as msc.cfg. If you can not find such a file, perhaps every time you start it, it will compain about the directories.
As for the settings of directories, please go to the "System Directories" tab of the "System Config" dialog, check "Guess the other directories when one of them is set", and click the button right of the first "Mapserver Utilities Directory", locate to the "shp2img.exe"  file, for MS4W could be "C:\ms4w\tools\mapserv\shp2img.exe", then if you have MS4W installed, it should verify the other directories correctly.
if the directories are right, usually it should work. Please tell me if the problem is still there.
Good luck,
enri.
>Hi,
>Thanks of this - I think it could become a very useful tool - but at
>the moment I have some problems.
>I have the latest version of MS4W installed in C:\MS4W - despite the
>configuration pointing at this it still said it couldn't find the
>directories at first
>Eventually - after restarting several times it no longer complained
>about the directories (although they were still pointing to the same
>place??)
>Now it opens up - but when I create a new map and goto add a layer it
>just tells me I have an Access violation at adresss xxxxx
>Best wishes
>James
>2009/2/21 enri <enri at 163.com>:
>> Hi,
>> Several months ago, I planned to contribute a mapfile editor to you, the
>> Mapserver community. After many overnights' hard work, the first alpha
>> version, a totally WYSWYG mapfile editor - MSCompanion is finally available
>> now. Please find it at http://code.google.com/p/mscompanion/ and check if it
>> can help you. Also I am waiting for your response and suggestion.
>> Enri
>> ________________________________
>> ÍøÒ×ÓÊÏ䣬ÖйúµÚÒ»´óµç×ÓÓʼþ·þÎñÉÌ
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>Dr James Perrins
>exeGesIS SDM Ltd
>Great House Barn
>New Street, Talgarth
>Powys LD3 0AH.
>Direct Line: 01646 686650
>Tel: 01874 711145
>Fax: 01874 711156
>Email: JamesP at esdm.co.uk
>This E-mail and any files transmitted with it are private and intended
>solely for the use of the individual or entity to whom they are
>addressed. If you are not the intended recipient, the E-mail and any
>files have been transmitted to you in error and any copying,
>distribution or other use of the information contained in them is
>strictly prohibited.
>Nothing in this E-mail message amounts to a contractual or other legal
>commitment on the part of exeGesIS SDM Ltd unless confirmed by a
>signed communication.
>exeGesIS SDM Ltd will make every effort to keep its network free of
>viruses. However, the recipient of this message will need to scan this
>message, and any attachments, for viruses, as exeGesIS SDM Ltd can
>take no responsibility for any computer virus that might be
>transferred by this e-mail.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090222/aea55b6e/attachment.html
