[mapserver-users] Status on ticket 2582?
paalkr pal.kristensen at statkart.no
Sun Feb 22 12:45:12 EST 2009
Hi!
Will this prevent the layer from being rendered, because that is not what we
want? If the STATUS is set to default the intention is that the "hidden"
layers shall be drawn. What about using [service]_hide instead of
[service]_dump? Dump eq false kind of sounds like the layer is totally
disabled, hence the question above. An other option could be
[service]_expose, which then defaults to true.
Other than that I like the idea of disabling all request, not only
GetCpabilities.
Regards,
Pål Kristensen
Alan Boudreault wrote:
> I'm currently making a similar patch. I didn't see the ticket 1952
> before. It will use "[service]_dump" metadata. ie. "wms_dump" set to
> false (true by default) will disable this layer for all possible
> requests (not only the getcapabilities). It should be in 5.4 beta 2.
> Alan
> paalkr wrote:
>> Sorry! Didn't look at the patch prior to writing the comment. Obviously
>> Martin has taken care of all the service types. I see no reason why the
>> patch not should enter trunk (and 5.4 branch)  and become a part of the
>> next
>> 5.4 beta.
>> Regards,
>> Pål Kristensen
>> paalkr wrote:
>>> @Devs; what about incorporating this patch into the core and finally fix
>>> the issue? I guess the remaining work is to apply support for other
>>> services than WMS (i.e. wfs, sos, wcs), and documentation of course :-)
>>> Regards,
>>> Pål Kristensen
>>> Martin Kofahl wrote:
>>>> Hi,
>>>> I did add a patch for ms540-b1 to ticket #1952
>>>> [http://trac.osgeo.org/mapserver/ticket/1952]. It uses a
>>>> ows_hidden_layer metadata and does also solve ticket #2582. It does
>>>> also
>>>> work for layers grouped by using the wms_layer_group metadata and does
>>>> otherwise work as described i my last post.
>>>> Martin
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Status-on-ticket-2582--tp2337548p2368388.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
