[mapserver-users] GetFeatureInfo with ArcSDE9.1/Oracle10g
Spatial Views - Mapserver 5.2
Stephan Holl
stephan.holl at intevation.de
Mon Feb 23 03:20:02 EST 2009
Hello Michelle,
Michelle Douvil <mrdouville at shaw.ca>, [20090220 - 15:34:34]
> Additional debugging info..
> [Fri Feb 20 15:18:05 2009].241000 msSDELayerOpen(): Layer
> BIOT_OCCR_TREES_AREA_SVW specified version SDE.DEFAULT.
> [Fri Feb 20 15:18:05 2009].241000 msSDEGetLayerInfo(): Looking for
> layer by WHSE_TERRESTRIAL_ECOLOGY.BIOT_OCCR_TREES_AREA_SVW, GEOMETRY,
> server,port:port,sde,username,password
> [Fri Feb 20 15:18:05 2009].241000 msSDEGetLayerId(): Matched layer to
> id 896.
> [Fri Feb 20 15:18:05 2009].241000 Getting all column information in
> msSDELayerInitItemInfo
> [Fri Feb 20 15:18:05 2009].241000 msSDELayerGetRowIDColumn(): Table
> was not registered, returning SE_ROW_ID.
Make sure that your Layer is registerd properly in our ArcSDE,
otherwise you will not be able to fetch the GetFeatureInfo.
> [Fri Feb 20 15:18:05 2009].241000 msSDELayerGetShape(): SDE
error.
> SE_stream_fetch_row(): Invalid parameter value passed to function.
> (-66) [Fri Feb 20 15:18:05 2009].241000 mapserv request processing
> time (msLoadMap not incl.): 0.016s
> [Fri Feb 20 15:18:05 2009].241000 msFreeMap(): freeing map at
> 010B4548. [Fri Feb 20 15:18:05 2009].241000
> msSDELayerCloseConnection(): Closing connection for layer
> BIOT_OCCR_TREES_AREA_SVW.
Best
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090223/3062f92a/signature.bin
