[mapserver-users] MapServer problem
Phalguni Pal phalguni.pal at gmail.com
Mon Feb 23 12:47:27 EST 2009
Hi Mapserver users,
I am trying to display few points on the browser using Mapserver. I have
created MySQL database and created connection with mapserver by the help of
.ovf xml file.
<OGRVRTDataSource>
    <OGRVRTLayer name="nsdb">
             <SrcDataSource>MYSQL:dispro,user=uuuuuu,password=pppp,host=192.170.1.100,port=3306,tables=STATION</SrcDataSource>
        <SrcSQL>SELECT absnum, stlat, stlon, stflag FROM STATION</SrcSQL>
        <GeometryType>wkbPoint</GeometryType>
        <GeometryField encoding="PointFromColumns" x="stlon" y="stlat"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
When I run the command :
ogrinfo  /mnt/fritjof/wms/nsdb/con.ovf
ogrinfo returns :
ERROR 4: Update access not supported for VRT datasources.
Had to open data source read-only.
INFO: Open of `/mnt/fritjof/wms/nsdb/con.ovf'
      using driver `VRT' successful.
1: nsdb (Point)
Version details of mapserver and GDAL as follows:
$ ./mapserv -v
MapServer version 4.10.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=EPPL7 INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE DEBUG=MSDEBUG
$ gdal-config --version
1.5.3
- Show quoted text -
I have a map file con.map as follows:
MAP
  NAME "MYSQL-TEST"
  EXTENT  -180 -90 180 90
  UNITS dd
  CONFIG "CPL_DEBUG" "ON"
  PROJECTION
  "init=epsg:4326"
  END
  SHAPEPATH "/mnt/fritjof/wms/nsdb"
  LAYER
    DEBUG ON
    METADATA
      "wms_title" "nsdb"
      "wms_srs" "EPSG:4326"
      "wms_extent" "-57.768 64.1842 -51.6283 64.3645"
    END
    NAME "stations"
    STATUS DEFAULT
    TYPE POINT
    CONNECTIONTYPE OGR
    CONNECTION "con.ovf"
    DATA "nsdb"
    PROJECTION
      "init=epsg:4326"
    END
    EXTENT -57.768 64.1842 -51.6283 64.3645
    CLASS
      NAME "MyClass"
      STYLE
        SYMBOL 1
        SIZE 15
        COLOR 255 0 0
          END
    END
 END
END
And I have another html form from where I am trying to display in browser
the Latitude and longitude points which are stored in database.
MAPFILE
REQUEST
SERVICE
VERSION
LAYERS
STYLES
SRS
BBOX
WIDTH
HEIGHT
FORMAT
But Mapserver is displaying nothing and does not giving any error. Just it's
showing a blank map. Could you tell me Why??
What's the problem may be happen??
Thanking you.
Regards,
Phalguni
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090223/f7b8377e/attachment.html
