[mapserver-users] Status on ticket 2582?
paalkr pal.kristensen at statkart.no
Mon Feb 23 17:40:50 EST 2009
Great!
Regards,
Pål Kristensen
Alan Boudreault wrote:
> I'll make the RFC in the next days.
> Alan
> On February 23, 2009 01:09:36 pm Steve Lime wrote:
>> Hi guys: I think we need a small RFC on this issue. The impacts are too
>> broad to handle
>> without a formal plan. Anyone care to take the lead?
>> Steve
>> >>> On 2/22/2009 at 4:51 PM, in message
>> <1235343099022-2369505.post at n2.nabble.com>,
>> paalkr <pal.kristensen at statkart.no> wrote:
>> > Hi!
>> > Good idea, this could even make the dump == false / true for OWS
>> redundant.
>> > Adding wfs_disable_request 'all' would effectively prevent wfs
>> support.
>> > Adding wms_disable_request 'GetFeatureinfo' would be the same as dump
>> > false on a WMS layer.
>> > I think the following situations are the most common where this
>> "hiding"
>> > functionality would be needed:
>> > 1) Adding a "copyright" statement to a map. Hiding the layer and
>> setting
>> > status to default will insure that the label is rendered regardless
>> of
>> > requested layers.
>> > 2) Exposing different raster resolution layers as one "logical"
>> layer. This
>> > can be achieved in two different ways
>> > a) adding all the raster layers (status == default) to a group as
>> hidden
>> > layers (the group will (should) then become hidden as well), then add
>> a
>> > "dummy" layer (which don't draws anything) with the same name as the
>> group.
>> > Requesting the dummy layer would actually also request the group
>> because the
>> > name is identical.
>> > b) adding all the layers as hidden single layers (status == default)
>> and use
>> > the requires mechanism to set dependencies to a "dummy" layer.
>> > 3) Hiding tileindex layers. Setting up the tileindex as a separate
>> layer is
>> > the only way of adding a tileindex to e.g PostgreSQL atm.
>> > 4) Enable / expose some layers only for certain service types (wms,
>> wfs,
>> > sos, wcs)
>> > 5) Limit the "users" ability to interact and change the map
>> appearance.
>> > Anyway. I hope that either Martins patch is added to 5.4 or that we
>> agree on
>> > something similar, in time to reach the 5.4 release.
>> > Regards,
>> > Pål Kristensen
>> > Martin Kofahl wrote:
>> >> Hi,
>> >> it becomes apparent that we try to solve different issues with
>> hiding,
>> >> ignoring and so on. We should try to find an implementation which
>> also
>> >> solves related tickets but is open for future requirements.
>> >> So couldn't we use a metadata like [service]_disable_request which
>> lists
>> >> all request type (per service) MapServer shouldn't support for a
>> layer?
>> >> Maybe expanded with the request type 'all'. Possible examples:
>> >>      wms_disable_request 'all'
>> >>      wms_disable_request 'getcapabilities getfeatureinfo'
>> >> This should solve tickets 337, 1952, 2582.
>> >> What do you think?
>> >> Martin
>> > View this message in context:
>> > http://n2.nabble.com/Status-on-ticket-2582--tp2337548p2369505.html
>> > Sent from the Mapserver - User mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://n2.nabble.com/Status-on-ticket-2582--tp2337548p2374868.html
