[mapserver-users] showing blank page
Alexandre Dube
adube at mapgears.com
Tue Feb 24 08:10:57 EST 2009
Put this in your MAP section :
CONFIG MS_ERRORFILE "/tmp/mymapfileerror.log"
and this in your LAYER section :
DEBUG 5
Load your url and go see what the error log has to say. You can also
check your apache and error logs.
Regards,
Alexandre
kmanoj-pg7 kmanoj-pg7 wrote:
> Dear users,
> I am following the tutorial mapserver 5.x to get a practice in the
> mapserver. i successfully tested the examples given in the tutorial
> and got succeed too...
> now i am trying by my own, means with my own shapefiles. when i called
> the following link...
> http://localhost/cgi-bin/mapserv?map=/var/www/html/mapfiles/sampletest/htdocs/kerala.map&layer=kerala&mode=map
> <http://localhost/cgi-bin/mapserv?map=/var/www/html/mapfiles/sampletest/htdocs/kerala.map&layer=kerala&mode=map>
> it showing blank page instead of image of my map........ what could
> be a problem...... i couldn't puzzled it out.....
> This is my map file for your perusal
> Map
> IMAGETYPE PNG
> NAME "Gods own country"
> SIZE 400 300
> IMAGECOLOR 255 255 255
> EXTENT -97.238976 41.619778 -82.122902 49.385620
> SHAPEPATH "/var/www/html/mapfiles/sampletest/data"
> LAYER
> NAME kerala
> TYPE POLYGON
> STATUS ON
> DATA parl_04
> CLASS
> NAME "Greenary Land"
> STYLE
> COLOR 232 232 232
> OUTLINECOLOR 32 32 32
> END
> END
> END
> END
> can anyone help me out.....
> Thanks
> kapilmanoj
> mapserver-users at lists.osgeo.org
Alexandre Dubé
Mapgears
www.mapgears.com
