[mapserver-users] wcs client support
Roger André randre at gmail.com
Fri Feb 27 18:23:22 EST 2009
Hi Frank,
Apologies if this is a dense question, but is it correct to assume the
following:
1) create an XML file similar to this one that points at valid WCS service:
<WCS_GDAL>
  <ServiceURL>http://maps.gdal.org/cgi-bin/mapserv_dem?</ServiceURL>
  <CoverageName>srtmplus_raw</CoverageName>
</WCS_GDAL>
2. Create a Mapserver LAYER with TYPE raster, and where the DATA line
points to the above-mentioned XML file.
Is that it?  Do I need to specify in the LAYER something special for
Mapserver to use GDAL to query the WCS via the XML file? (whew, say
that 3x fast)
Thanks,
Roger
On Fri, Feb 27, 2009 at 2:38 PM, Roger André <randre at gmail.com> wrote:
> Hi Frank,
> I didn't know about the gdal WCS driver.  I'll see if I can get
> something working from the doc you've linked to.
> Thanks,
> Roger
> On Fri, Feb 27, 2009 at 2:04 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> Roger André wrote:
>>> Hi All,
>>> Does anyone know of any work being done to implement WCS client
>>> functionality in Mapserver?  I have seen a passing reference to this
>>> on the OGC Galeon page, http://www.ogcnetwork.net/node/113. It looked
>>> like Texas A&M was going to implement a test client, but I can't find
>>> any additional info about this.
>>> I'd like to make some maps using data stored on WCS servers, but I
>>> can't seem to find any clients that can render the data directly.
>> Roger,
>> GDAL already has a WCS driver so the normal approach to serving maps
>> from WCS sources is to use MapServer and GDAL's WCS driver.  Within reason
>> I can provide assistance trying this out.
>>  http://www.gdal.org/frmt_wcs.html
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Programmer for Rent
