[mapserver-users] wcs client support
Roger André randre at gmail.com
Fri Feb 27 18:56:13 EST 2009
Unbelievable.  This is really incredible.  Works like a champ.
Thanks for your help.
On Fri, Feb 27, 2009 at 3:38 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Roger André wrote:
>> Hi Frank,
>> Apologies if this is a dense question, but is it correct to assume the
>> following:
>> 1) create an XML file similar to this one that points at valid WCS
>> service:
>> <WCS_GDAL>
>>  <ServiceURL>http://maps.gdal.org/cgi-bin/mapserv_dem?</ServiceURL>
>>  <CoverageName>srtmplus_raw</CoverageName>
>> </WCS_GDAL>
>> 2. Create a Mapserver LAYER with TYPE raster, and where the DATA line
>> points to the above-mentioned XML file.
>> Is that it?
> Yes
>> Do I need to specify in the LAYER something special for
>> Mapserver to use GDAL to query the WCS via the XML file? (whew, say
>> that 3x fast)
> No, nothing special.  As far as MapServer knows this is just
> another raster file.  I will note that the XML file with the WCS
> definition needs to be writable as the first time it is accessed
> GDAL will fetch the WCS capabilities and add a bunch more detail in
> the XML file.  You might want to even trigger this in advance with
> gdalinfo to ensure things are working ok.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
