[mapserver-users] Rotated TrueType Point Symbols - Issue
thomas bonfort
thomas.bonfort at gmail.com
Fri Jan 2 12:02:01 EST 2009
ttf rotation is fixed in trunk for agg. the point of rotation is the
centre of the symbol.
regards,
thomas
On Fri, Jan 2, 2009 at 17:29, Fawcett, David <David.Fawcett at state.mn.us> wrote:
> Donald,
> I have seen this same issue using MapServer 5.2.0. I first noticed it
> when I was doing an attribute binding example, but I can confirm that it
> also occurs when using a fixed angle.
> When specifying a fixed angle of 0 or 360, the symbol lands correctly on
> the point. An angle of 90 sets it off of the point to the left. 180
> puts it to the lower left, 270 is lower center, 359 is almost back on
> center.
> The more that I look at this, it really looks like it is This related to
> the proper centering of symbols. My square .ttf character appears to be
> rotating around the lower left corner of the glyph. When the symbol is
> placed unrotated, it is correctly centered on the point feature. So,
> maybe the rotation point needs to be calculated the same way as the
> placement point.
> I was quickly trying to pull together a demo, so I abandoned the .ttf
> approach and used a pixmap symbol of an arrow.
> I think that it is likely a bug, I should have filed a bug report back
> then. I will do so now if you aren't interested in doing it.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald
> Kerr
> Sent: Friday, January 02, 2009 9:58 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Rotated TrueType Point Symbols - Issue
> I have created a number of TrueType symbols most of which are good
> enough when positioned on the map at their default centre point.
> There appears to be an issue when these are then rotated using ANGLE.
> They do not appear to rotate around their centre point which can make
> them look very odd when placed on the map.
> Please see attached images one showing without the ANGLE applied and the
> other with. If the symbol rotated around its centre point then the arrow
> would simply show pointing the other way (180 degrees).
> I tried to make a TTF symbol that had the head of the arrow in the
> centre in the hope that it would rotate on this point. It shows
> correctly when no ANGLE is applied i.e. the head of the arrow over the
> point on the map but, when rotated, the error in placement is
> exaggerated.
> Here are the CLASS and SYMBOL definitions:
> CLASS
> NAME "benchMarkSymbol"
> EXPRESSION "benchMarkSymbol"
> STYLE
> SYMBOL "benchMarkSymbol"
> SIZE 12
> MAXSIZE 12
> MINSIZE 4
> COLOR 0 0 0
> ANTIALIAS TRUE
> ANGLE [orientation]
> END # STYLE
> END # CLASS
> SYMBOL
> NAME 'benchMarkSymbol'
> TYPE TRUETYPE
> FONT OSMasterMapSymbols
> FILLED false
> ANTIALIAS true
> CHARACTER '7'
> END # SYMBOL
> The question is, am I doing something wrong or is this a bug? If the
> latter, is there a workaround meantime? For me just now, I'd be happy if
> the symbol rotated around its centre - I could live with that as a
> workaround.
> In a previous thread that I started about positioning of LABELs, Thomas
> Bonfort said, "I'd be in favor of having a way to specify the anchor
> point, either by fixing it on 0,0 , or by specifying it alongside the
> symbol, eg ANCHORPOINT 0.3 2". I agree that this would be good for
> symbols too but it may present a problem with scaled symbols, especially
> TTF. If it's not a fixed size then how can an anchor point be specified?
> Many thanks.
> Regards,
> Donald Kerr
