[mapserver-users] Overriding MapServer Map File Parameters
inOpenLayers
Bill Thoen
bthoen at gisnet.com
Fri Jan 2 14:40:01 EST 2009
Thanks David! You gave me the hint I needed. If I leave out the '+'
characters and use spaces instead then this works:
var baseLayer = new OpenLayers.Layer.MapServer( "USA",
"http://206.168.217.244/cgi-bin/mapserv?",
'map_imagetype': 'PNG',
layer: 'states',
"map.layer[states].class[0].style[0]": "COLOR 255 255 0",
map: '/var/www/html/piper/usa.map'
singleTile: true
However, if you're doing this via URL, you have to substitute '+' for
spaces.
- Bill Thoen
Fawcett, David wrote:
> Bill,
> Here is something that I have tested in 5.2
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/workshop08/runtime_s
> ub_config.map&mode=map&map.layer[counties].class[0].style[0]=COLOR+178+3
> 4+34+WIDTH+3
> It changes both the color and width of the line feature, just drop the
> '+WIDTH+3' off of the end.
> Also, I recommend testing your substitution like this directly in the
> URL before attempting to pass it from OpenLayers.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bill Thoen
> Sent: Friday, January 02, 2009 12:23 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Overriding MapServer Map File Parameters
> inOpenLayers
> I'm trying to make a map in OpenLayers 2.7 using a MapServer 5.0.3 Map
> File, and I'm trying to change the Layer color from what's specified in
> the Map File. In OpenLayers, I have to format the parameter as a key:
> value pair. So here's what I've tried (without success) in my OL
> javascript:
> map_imagetype: 'PNG',
> layer: 'states',
> map_layer_0_class_0_style_0_color: '255+255+000',
> }, { singleTile: true });
> If I take out this line:
> the map works fine. The only layer in the map is the US states, and all
> I want to do is change the color from pale yellow as set in the map file
> to bright yellow.
> The relevant part of the map file looks like this:
> LAYER
> NAME "states"
> TYPE POLYGON
> DATA states
> CLASS
> NAME "US States"
> STYLE
> OUTLINECOLOR 100 100 100
> COLOR 255 255 192
> END
> END
> PROJECTION
> "init=epsg:32614" # UTM Zone 14 N WGS84
> END
> STATUS DEFAULT
> END
> I think the problem is that I've got the syntax wrong in trying to
> override the MapServer map file parameter. I've looked at
> http://mapserver.osgeo.org/cgi/controls.html#changing-map-file-parameter
> s-via-a-form-or-a-url
> but that hasn't helped. So does anyone *here* know how to do this? (I
> was told on the OpenLayers mailing list to try asking on the MapServer
> list.)
> TIA,
> - Bill Thoen
