[mapserver-users] Rotated TrueType Point Symbols - Issue
Donald Kerr
donald.kerr at dkerr.co.uk
Mon Jan 5 17:28:34 EST 2009
David
> Are you saying that you are using the latest trunk code and
> you are still seeing this problem?
In a previous reply I got from Thomas Bonfort who asked much the same
question as you are above, I asked "Are you referring to "Revision 8379:
/trunk"?" and "I'm working with version 5.2.1 downloaded with the MS4W
package."
To be honest, I don't know if this is the latest or not and I don't really
know what "trunk code" is :(
I also wrote in the same email to Thomas, "If that's the case, I assume that
I would have to download and compile the files then overwrite my existing
files. This is my first bash at MapServer and it's a steep learnig curve!"
Thomas hasn't replied as yet.
So, I suppose my questions are still the same i.e. do I have to recompile
using the latest code? Yikes!
To give you some more info, I also created a square symbol to see how that
rotated and it didn't show correctly at all. I've attached a couple of
images showing an arrow symbol (not square) which, when rotated, appears to
rotate on the bottom left corner. I could live with the symbol rotating on
its centre by creating something with the arrow head in the middle and
putting a couple of tiny dots in the font character so that it appears to be
a large square - Like so (the following probably won't come out right but it
will give you an idea):
Not ideal as the dots would show but they would be tiny - as I say, I could
live with that. It would be ideal if an anchor point could be specified but
how that could be done with a ttf and scaling I do not know :(
Many thanks,
Regards,
Donald
-----Original Message-----
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: 05 January 2009 20:47
To: Donald Kerr; thomas bonfort
Subject: RE: [mapserver-users] Rotated TrueType Point Symbols - Issue
Donald,
Are you saying that you are using the latest trunk code and you are
David.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald
Kerr
Sent: Friday, January 02, 2009 11:42 AM
To: 'thomas bonfort'; 'Fawcett, David'
Cc: mapserver-users at lists.osgeo.org
Thomas,
> ttf rotation is fixed in trunk for agg. the point of rotation
> is the centre of the symbol.
That doesn't seem to be the case. If I rotate a TTF symbol then it
appears offset as per the images I posted to the group earlier.
Regards,
Donald
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090105/de855051/NoANGLE.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090105/de855051/WithANGLE.png
