[mapserver-users] Color palette for road-like layers
Paul Spencer
pspencer at dmsolutions.ca
Tue Jan 6 08:08:10 EST 2009
Adrian,
that is a fairly simple trick, you need to draw roads twice to do it.
You can do that with two separate layers or two STYLE objects within a
class depending on what effect you want to achieve.
In both cases, you just draw the road 2 pixels wider in your 'outline'
color (called a casement). For instance, assuming you are using two
STYLE objects:
LAYER
NAME "Major Roads"
TYPE LINE
DATA myroads
CLASS
NAME "Major Roads"
STYLE #Casement style
SIZE 9
COLOR 192 192 192
SYMBOL "circle"
END
STYLE #Center style
SIZE 7
COLOR 255 255 255
SYMBOL "circle"
END
END
END
You would use two separate layers to draw the casement and center
style if you had several layers and/or classes of roads that you
wanted to 'merge' the casements - in your google screenshoot, you
should notice that the grey casement on Hollywood St merges with the
casement on W 8th St and there is no grey line between the two center
colors, this would be how to achieve a similar effect in MapServer.
Cheers
Paul
On 6-Jan-09, at 3:51 AM, Adrian Popa wrote:
> Yes Bob, I like the roads. :)
> Can you show me how you are able to draw contours around your roads?
> Thanks
> Bob Basques wrote:
>> Adrian,
>> Would the lines used for this map work for you?
>> https://gis.ci.stpaul.mn.us/gis/gismo_public/html/
>> Looks like the original Mapfile link is broken though, I'll need to
>> fix that in the morning.
>> bobb
> Adrian Popa
> Network Engineer
> Romtelecom S.A.
> Divizia Centrul National de Operare Retea
> Departament Transport IP & Metro
> Compartiment IP Core
> mapserver-users at lists.osgeo.org
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
