[mapserver-users] Showing pop up for a line
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Jan 6 10:31:18 EST 2009
Why not use straight MapServer queries? Set a reasonable tolerance and that should
work ok too.
Steve
>>> On 1/6/2009 at 12:04 AM, in message <4962F45D.3010103 at gslab.com>, Subha
Ramakrishnan <subha at gslab.com> wrote:
> Hi,
> I am using Mapserver 5.0.2 with Openlayers.
> I've a line layer (from mapserver) shown on my base map(google physical).
> Now, when i click on a line, i want to show a pop using openlayers.
> I am able to do this for a polygon layer. I send the lat,lon of the
> point that is clicked and use the postgis query
> "ST_Contains(topology,geomFromText('POINT(77.87117958068927
> 13.491965860913544)',-1))" to find the polygon (and fetch the polygon
> specific data to show on pop up) and attach the Openlayers popup to the
> point clicked.
> I am not able to do this for a line layer as the postgis query doesn't
> return anything.
> I tried this query also,
> 13.491965860913544)',-1)) AND
> distance(topology,geomFromText('POINT(77.87117958068927
> 13.491965860913544)',-1)) <= 1" but it doesn't work.
> Does any one know how to check if a point is a part of a line or if
> there is any other way to show the pop up?
> Thanks a lot for the help.
> Regards,
> Subha
> mapserver-users at lists.osgeo.org
