[mapserver-users] queryByRect throws an error
Tamas Szekeres szekerest at gmail.com
Tue Jan 6 15:33:01 EST 2009
Could you provide a code/mapfile sample to reconstruct the issue? I've never
experienced such a problem, I've used this function many times though.
Best regards,
Tamas
2009/1/6 Murty Maganti <MMaganti at oriongis.com>
>  mapObj.queryByRect(…)  (using C# map script) is throwing following
> exception when there is an embedded scale bar on map.
> Exception message: "msShapefileOpen(): Unable to access file. No (NULL)
> filename provided.;msBuildPath: Unable to access file"
> Removing the scale bar from map file works fine.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090106/12e71c9e/attachment-0001.html
