[mapserver-users] MapServer 5.2.1 and AGG/PNG - too thick lines
in the grid
thomas bonfort
thomas.bonfort at gmail.com
Wed Jan 7 03:21:58 EST 2009
that's what antialiasing is supposed to do, as your 1 pixel wide grid
doesn't fall exactly on a pixel.
I don't think there is a workaround.
regards,
thomas
On Mon, Jan 5, 2009 at 13:28, Maximsu <maxims731 at inbox.ru> wrote:
> I have very thick lines in the grid layer when i use agg/png driver. See the
> map http://avia.meteonovosti.ru/index.php?index=1&icao=UUEE&iso_cntr=RU
> here . They must be the 1 pixel width. With the gd/png driver all OK. Width
> is set to 1 but it does not matter. Is there a way to switch off the line
> antialiasing for grid layer? Or some another way to solve this problem?
> There is the layer definition:
> LAYER
> NAME grid2
> GROUP "Grid"
> STATUS ON
> TYPE LINE
> LABELCACHE ON
> MINSCALE 1000001
> MAXSCALE 3000000
> METADATA
> GridLabelSizeMin "8"
> GridLabelSizeMax "11"
> END
> CLASS
> NAME "Graticule"
> STYLE
> COLOR 72 72 72
> width 1
> END
> LABEL
> COLOR 255 0 0
> SIZE 8
> POSITION CC
> PARTIALS TRUE
> BUFFER 5
> OUTLINECOLOR 255 255 255
> TYPE TRUETYPE
> FONT "arial"
> FORCE TRUE
> END
> END
> PROJECTION
> "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
> END
> GRID
> LABELFORMAT "DD"
> MinInterval 1
> MaxInterval 5
> END
> END
> View this message in context: http://n2.nabble.com/MapServer-5.2.1-and-AGG-PNG---too-thick-lines-in-the-grid-tp2112673p2112673.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
