Fw: [mapserver-users] error compilation for mapserver 5.2.1
Tamas Szekeres szekerest at gmail.com
Thu Jan 8 04:28:17 EST 2009
We use MSVC_VER=1400 setting with MSVC2005 and SWIG-1-3-33, but I'll also
try to compile with a newer version. Does this problem occurs when compiling
the csharp stuff solely?
Best regards,
Tamas
2009/1/8 sandric ionut <sandricionut at yahoo.com>
> Sorry:
> And the nmake.opt file
>  Hi Tamas:
> I have attached the nmake.opt file. I have downloaded the source code for
> mapserver 5.2.1. from the mapserver website and than I have followed the
> intructions to compile mapserver
> I have tried with both visual studio command promt and vcvars32.bat. I get
> the same error
> Thank you,
> Ionut
> *From:* Tamas Szekeres <szekerest at gmail.com>
> *To:* sandric ionut <sandricionut at yahoo.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Sent:* Thursday, January 8, 2009 12:42:45 AM
> *Subject:* Re: [mapserver-users] error compilation for mapserver 5.2.1
> Hi Ionut,
> I'm guessing the library files and the includes you're compiling against
> might not relate to the same version. Could you provide a diff how you alter
> nmake.opt when compiling mapserver? Do you use the Visual Studio Command
> prompt or set up the environment manually (like using vcvars32.bat or
> something).
> Best regards,
> Tamas
> 2009/1/7 sandric ionut <sandricionut at yahoo.com>
>>  Hello:
>> I try to compile mapserver 5.2.1. using Microsoft Visual Studio 2005. I
>> have made the proper modifications to the nmake.opt file and run the compile
>> command as:
>> nmake -f makefile.vc charp
>> After several errors (which I've managed to pass), I've the following
>> error (see bellow)
>> How can I correct this?
>> Thank you in advance
>> Ionut
>> -DUSE_THREAD    -DIGNORE_MISSING_DATA   -DENABLE_STDERR_DEBUG
>> -DUSE_
>> GD_ANTIALIAS       -DUSE_ZLIB    -DUSE_AGG   -DWIN32 -D_WIN32 /c
>> mapraster.c /Fo
>> mapraster.obj
>> mapraster.c
>> C:\Program Files\Microsoft Visual Studio
>> 8\VC\PlatformSDK\include\winnt.h(327) :
>>  warning C4005: 'TEXT' : macro redefinition
>>         h:\kit\mapserver-5.2.1\mapfile.h(123) : see previous definition of
>> 'TEXT
>> 8\VC\PlatformSDK\include\windef.h(343)
>> : error C2059: syntax error : 'constant'
>> 8\VC\PlatformSDK\include\windef.h(345)
>> 8\VC\PlatformSDK\include\windef.h(346)
>> 8\VC\PlatformSDK\include\windef.h(357)
>> 8\VC\PlatformSDK\include\wingdi.h(98) :
>>  warning C4005: 'ERROR' : macro redefinition
>>         h:\kit\mapserver-5.2.1\mapfile.h(52) : see previous definition of
>> 'ERROR
>> 8\VC\PlatformSDK\include\wingdi.h(879)
>> : error C2061: syntax error : identifier 'SIZEL'
>> 8\VC\PlatformSDK\include\wingdi.h(880)
>> : error C2061: syntax error : identifier 'szlMillimeters'
>> : error C2059: syntax error : ';'
>> 8\VC\PlatformSDK\include\wingdi.h(890)
>> : error C2061: syntax error : identifier 'szlMicrometers'
>> 8\VC\PlatformSDK\include\wingdi.h(893)
>> : error C2059: syntax error : '}'
>> 8\VC\PlatformSDK\include\wingdi.h(1103)
>> 8\VC\PlatformSDK\include\wingdi.h(1104)
>> 8\VC\PlatformSDK\include\wingdi.h(1105)
>> 8\VC\PlatformSDK\include\wingdi.h(1106)
>> 8\VC\PlatformSDK\include\wingdi.h(1557)
>>  : warning C4005: 'TRANSPARENT' : macro redefinition
>>         h:\kit\mapserver-5.2.1\mapfile.h(130) : see previous definition of
>> 'TRAN
>> SPARENT'
>> 8\VC\PlatformSDK\include\wingdi.h(3025)
>>  : error C2146: syntax error : missing ')' before identifier 'lpsize'
>>  : error C2081: 'LPSIZE' : name in formal parameter list illegal
>>  : error C2061: syntax error : identifier 'lpsize'
>>  : error C2059: syntax error : ')'
>> 8\VC\PlatformSDK\include\wingdi.h(3049)
>> 8\VC\PlatformSDK\include\wingdi.h(3203)
>>  : error C2146: syntax error : missing ')' before identifier 'lpsz'
>>  : error C2061: syntax error : identifier 'lpsz'
>> 8\VC\PlatformSDK\include\wingdi.h(3204)
>> 8\VC\PlatformSDK\include\wingdi.h(3212)
>> 8\VC\PlatformSDK\include\wingdi.h(3213)
>> 8\VC\PlatformSDK\include\wingdi.h(3227)
>>  : error C2146: syntax error : missing ')' before identifier 'psizl'
>>  : error C2061: syntax error : identifier 'psizl'
>> 8\VC\PlatformSDK\include\wingdi.h(3228)
>> 8\VC\PlatformSDK\include\wingdi.h(3236)
>> 8\VC\PlatformSDK\include\wingdi.h(3237)
>> 8\VC\PlatformSDK\include\wingdi.h(3254)
>>  : error C2146: syntax error : missing ')' before identifier 'lpSize'
>>  : error C2061: syntax error : identifier 'lpSize'
>> 8\VC\PlatformSDK\include\wingdi.h(3255)
>> 8\VC\PlatformSDK\include\wingdi.h(3266)
>> 8\VC\PlatformSDK\include\wingdi.h(3267)
>> 8\VC\PlatformSDK\include\wingdi.h(3489)
>> 8\VC\PlatformSDK\include\wingdi.h(3491)
>> 8\VC\PlatformSDK\include\wingdi.h(3727)
>> 'lpEnhMetaHeader'
>>  : error C2081: 'LPENHMETAHEADER' : name in formal parameter list illegal
>>  : error C2061: syntax error : identifier 'lpEnhMetaHeader'
>> 8\VC\PlatformSDK\include\wingdi.h(4009)
>> 8\VC\PlatformSDK\include\wingdi.h(4011)
>> 8\VC\PlatformSDK\include\wingdi.h(4016)
>> 8\VC\PlatformSDK\include\wingdi.h(4017)
>> 8\VC\PlatformSDK\include\wingdi.h(4018)
>> 8\VC\PlatformSDK\include\wingdi.h(4477)
>> 8\VC\PlatformSDK\include\wingdi.h(4478)
>> 8\VC\PlatformSDK\include\wingdi.h(4531)
>> 8\VC\PlatformSDK\include\wingdi.h(4532)
>> 8\VC\PlatformSDK\include\wingdi.h(4571)
>> 8\VC\PlatformSDK\include\wingdi.h(4572)
>> 8\VC\PlatformSDK\include\wingdi.h(4592)
>>  : fatal error C1003: error count exceeds 100; stopping compilation
>> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
>> 8\VC\BIN\c
>> l.EXE"' : return code '0x2'
>> Stop.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090108/9aa7e8f0/attachment-0001.html
