[mapserver-users] libgdal error with php/MapScript
Jacolin Yves
yjacolin at free.fr
Thu Jan 8 07:18:17 EST 2009
Hello,
I get an error when loading php_mapscript.so in my apache config.
Here is my config:
* Centos 4 (in an openvz system)
* PHP 4.3.9 (with GD 2.0.28)
* Apache 2
* GD 2.0.35
* AGG 2.4
* Mapserver 5.2.1
* geos 3.0.3
* gdal-ogr 1.6.0
* proj 4.6.1
MapServer configure:
./configure
--with-agg=/usr/local/src/build/agg-2.4
--with-postgis
--with-wmsclient --with-wfsclient
--with-geos --with-proj --with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/gdal-config
--with-php=/usr/include/php/
--with-freetype=/usr/bin/freetype-config --with-eppl --with-xpm=/usr/X11R6/lib/ --with-gd=/usr/local/ --with-python
GDAL-OGR configure:
./configure
--with-python
--with-pg=/usr/local/pgsql/bin/pg_config
--without-grass
After installing all dependance and set up php config to enable php_mapscript,
I try to look if php/mapscript is really enabled:
$ php -i | grep mapscript
give:
PHP Warning: Unknown(): Unable to load dynamic
library '/usr/lib/php4/php_mapscript.so' - libgdal.so.1: cannot open shared
object file: No such file or directory in Unknown on line 0
/etc/php.d/mapscript.ini
There is no mapscript table in phpinfo() function.
Any tips to find a solution?
Thanks in advance.
Y.
Yves Jacolin
http://softlibre.gloobe.org
