[mapserver-users] ippj-5.3.dll was not found
Dan Little danlittle at yahoo.com
Thu Jan 8 10:12:35 EST 2009
Did you make sure all the paths were properly setup?  I think you need to set an env variable to point to where the DLL's are located.
Also, Mapserver tends not to run really well from the commandline.  You'd need to set all of the environmental variables to account for the QUERY_STRING, etc.
----- Original Message ----
> From: boesiii <boesiii at yahoo.com>
> To: mapserver-users at lists.osgeo.org
> Sent: Thursday, January 8, 2009 8:03:08 AM
> Subject: [mapserver-users] ippj-5.3.dll was not found
> I just downloaded and installed OSGeo4w.  I tried to test out mapserv.exe at
> the command line but I get and error stating "Application failed to start
> because ippj-5.3.dll was not found. Reinstalling the application may fix
> this problem"
> I tried to reinstall but I still get the same error.
> http://n2.nabble.com/ippj-5.3.dll-was-not-found-tp2128008p2128008.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
