[mapserver-users] libgdal error with php/MapScript
Jacolin Yves
yjacolin at free.fr
Thu Jan 8 10:20:45 EST 2009
Hi Dan,
the test failed but now all is working, thanks :)
Y.
Le Thursday 08 January 2009 16:14:45 Dan Little, vous avez écrit :
> Another test would be to do this..
> (assumes a Bourne shell)
> export $LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
> Also, do a check on libgdal.so itself...
> ldd /usr/local/lib/libgdal.so.1
> Look for any "not found"s
> If php_mapscript.so is trying to link to libgdal.so and libgdal.so is
> linked to something it cannot find then the error will show up as not being
> able to link to libgdal.
> ----- Original Message ----
> > From: Jacolin Yves <yjacolin at free.fr>
> > To: Mapserver ML <mapserver-users at lists.osgeo.org>
> > Sent: Thursday, January 8, 2009 8:42:33 AM
> > Subject: Re: [mapserver-users] libgdal error with php/MapScript
> > Le Thursday 08 January 2009 15:39:14 Alan Boudreault, vous avez écrit :
> > > Yves,
> > > Did you look is there is any "libgdal.so*" file in the lib directory?
> > > If there's one... but it's not named "libgdal.so.1" .... maybe you
> > > could try to make a symbolic link to it.
> > > Alan
> > Alan,
> > the libgdal.so.1 exist, ls /usr/local/lib/libgdal* gives:
> > /usr/local/lib/libgdal.a
> > /usr/local/lib/libgdal.la
> > /usr/local/lib/libgdal.so.1.13.0
> > thanks
> > Y.
> > Yves Jacolin
> > http://softlibre.gloobe.org
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Yves Jacolin
