[mapserver-users] ippj-5.3.dll was not found
boesiii
boesiii at yahoo.com
Thu Jan 8 12:08:37 EST 2009
Thanks Franks,
I wiped out the folder and started from scratch, this time I only installed
what was necessary and that worked. I now have a functioning MapServer now
I need to figure out how built a webpage using it.
I was only running it from the command line to see if it was working.
Frank Warmerdam wrote:
> boesiii wrote:
>> I just downloaded and installed OSGeo4w. I tried to test out mapserv.exe
>> at
>> the command line but I get and error stating "Application failed to start
>> because ippj-5.3.dll was not found. Reinstalling the application may fix
>> this problem"
>> I tried to reinstall but I still get the same error.
> Hi,
> Did you by any chance install *all* OSGeo4W packages? This is really not
> wise because several packages depend on external items. One of these is
> the
> libjpeg-ipp package which depends on your having a special external
> package
> installed. To correct this particular item go into the advanced install,
> and select "reinstall" for the libjpeg package. This will replace the
> special
> IPP enhanced libjpeg with the standard one.
> However, if you have installed everything you will also likely have
> plugins
> for stuff like oracle, sde and ecw that depend on external components and
> may
> cause problems. It might be better to wipe your C:\OSGeo4W tree and
> reinstall
> somewhat more selectively.
> I think I may need to remove the libjpeg-ipp package since you aren't the
> first person to fall into the same trap.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/ippj-5.3.dll-was-not-found-tp2128008p2128911.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
