[mapserver-users] Mapserver MS SQL Server Spacial
Tamas Szekeres
szekerest at gmail.com
Fri Jan 9 04:07:06 EST 2009
You can use the mssql2008 plugin on Windows platforms to access MSSQL2008
spatial, the latest fixes have been incorporated in MapServer version 5.2.1
(2008-12-01)
Best regards,
Tamas
2009/1/8 Donald Kerr <donald.kerr at dkerr.co.uk>
> Is it possible to connect to MS SQL Server Spacial in the same was as
> PostGis?
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres dbname=MasterMap host=localhost"
> DATA "geom FROM topographicline USING UNIQUE toid"
> Or
> DATA "geom FROM (SELECT toid, featurecode, textstring, orientation/10 AS
> orientation, fontnumber, anchorposition, textstyle, geom FROM
> cartographictext) AS foo USING UNIQUE toid"
> If not, is there an alternative method without altering the database?
> Many thanks.
> Regards,
> Donald
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090109/fd4b6a9c/attachment.html
