[mapserver-users] Mapserver MS SQL Server Spacial
Tamas Szekeres
szekerest at gmail.com
Fri Jan 9 10:12:08 EST 2009
We would normally require an exact measure to interpret this conclusion by
describing the test environment settings and the data source settings in
both cases. You cannot easily place the equal-sign between the performance
of a cgi, fast cgi, or a mapscript application or even a single point layer
may highly outperform a layer with complex symbology for instance.
Best regards,
Tamas
2009/1/9 Roland Klabunde <roland.klabunde at freenet.de>
> No, not at all. It is just an impression. I was comparing MapDotNet Ux vs.
> MS24W. The latter is much more less performing...
> Tamas Szekeres schrieb:
>> 2009/1/9 Roland Klabunde <roland.klabunde at freenet.de <mailto:
>> roland.klabunde at freenet.de>>
>> ...but it is by far not that "performant", as e.g. MapDotNet
>> is.... I'm sorry to say that, but that's the way it is..
>> Do you have some measures to compare the performance? As far as I know
>> MapDotNet use this same driver along with MapServer as the drawing kernel.
>> The mssql2008 plugin have been contributed by ISC furthermore.
>> Best regards,
>> Tamas
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090109/c16cb096/attachment.html
