[mapserver-users] website upgrade for older documentation
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jan 9 17:24:47 EST 2009
Zach, et al,
It might be possible to do something like you are suggesting going
forward, as the documentation is been migrated into svn and should get
tagged with each release we do. Since this was not done in the past it
is unlikely that we can go backward in time with this type a scenario.
I think it will be up to the doc and web team to look into doing
something like this, but I believe the 1st step of having the docs in
svn is the critical pieces to be able to do anything like this.
I think you should write a ticket in the bug tracking system and then
post the tick number so interested parties can sign up to be CC on it.
Thanks,
   -Steve
zach cruise wrote:
> actually we just need to refer to old documentation for upgrading and
> porting, thanks though. if possible, we prefer something like
> http://www.mapserver.org/4.8/mapfile/map.html
> http://www.mapserver.org/5.2/mapfile/map.html
> much like
> http://www.postgresql.org/docs/8.1/interactive/sql-select.html
> http://www.postgresql.org/docs/8.1/static/sql-select.html
> http://www.postgresql.org/docs/8.2/interactive/sql-select.html
> http://www.postgresql.org/docs/8.2/static/sql-select.html
> On Thu, Jan 8, 2009 at 2:31 PM, Dan Little <danlittle at yahoo.com> wrote:
>> Zach,
>> Not trying to be a pushy guy... but is there a feature missing in 5.0 prevents you from upgrading?
>> ----- Original Message ----
>>> From: zach cruise <zachc1980 at gmail.com>
>>> To: Jeff McKenna <jmckenna at gatewaygeomatics.com>
>>> Cc: mapserver-users at lists.osgeo.org
>>> Sent: Thursday, January 8, 2009 12:31:26 PM
>>> Subject: Re: [mapserver-users] website upgrade for older documentation
>>> thanks. any way to search 4.8 documentation? any one got archived copy
>>> other than
>>> http://web.archive.org/web/20060701050731/http://mapserver.gis.umn.edu/?
>>> On Thu, Jan 8, 2009 at 12:21 PM, Jeff McKenna
>>> wrote:
>>>> zach cruise wrote:
>>>>> On Wed, Jan 7, 2009 at 5:29 PM, zach cruise wrote:
>>>>>> great website upgrade at http://www.mapserver.org/. how can i search
>>>>>> for older documentation like with postgresql.org?
>>>> The current (5.2.1) documents should have MapServer version references
>>>> inside them for specific functionality (such as a specific mapfile parameter
>>>> added in 5.0).
>>>> -jeff
>>>> Jeff McKenna
>>>> FOSS4G Consulting and Training Services
>>>> http://www.gatewaygeomatics.com/
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
