[mapserver-users] Path for errorfile
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Jan 10 09:19:53 EST 2009
Ben Madin wrote:
> G'day Daniel,
> On 09/01/2009, at 10:47 PM, Daniel Morissette wrote:
>> You are correct that relative paths are not supported for
>> MS_ERRORFILE. You could file a ticket about this, and if/when time
>> permits we'll look at the implications of supporting relative paths in
>> all possible scenarios and see if this could safely be added. i.e. it
>> may be possible to get predictable results with a relative path only
>> when setting MS_ERRORFILE in the mapfile but not when setting it via
>> an environment variable, we'll have to see.
> Thanks for the response, I have submitted it as a low priority
> enhancement (#2853), maybe just updating the documentation to clarify
> this point is enough for now. (Because I'm building on Mac OSX and
> deploying on FreeBSD, I'm a shameless user of relative references!)
> cheers
> Ben
Ben can you also file a ticket for the doc changes (in the "MapServer
Documentation" component)? I'll update them for you when you do that,
thanks.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
