[mapserver-users] Conexion with postgres-postgis
Alexandre Dube adube at mapgears.com
Mon Jan 12 13:11:37 EST 2009
Hi Valeria,
  What was the options you used with your shp2pgsql script execution ?
Did you specify a -s property ?
Alexandre
Valeria Muñoz wrote:
> HI
>   I am trying to connect postgres with my Mapfile, but I get the
> following error:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'chile_comuna'. prepare_database(): Query error. Error executing
> POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY
> CURSOR FOR SELECT
> "NAME"::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
> from chile_comuna WHERE the_geom && setSRID('BOX3D(-71.2556639435156
> -29.9271886101172,-71.2540857172265 -29.9256103838281)'::BOX3D,
> find_srid('','chile_comuna','the_geom') )' Postgresql reports the
> error as 'ERROR: column "NAME" does not exist LINE 1: DECLARE mycursor
> BINARY CURSOR FOR SELECT "NAME"::text,asbin... ^ ' More Help: Error
> with POSTGIS data variable. You specified 'check your .map file'.
> Standard ways of specifiying are : (1) 'geometry_column from
> geometry_table' (2) 'geometry_column from (sub query) as foo using
> unique column name using SRID=srid#' Make sure you put in the 'using
> unique column name' and 'using SRID=#' clauses in. For more help,
> please see http://postgis.refractions.net/documentation/ Mappostgis.c
> - version of Jan 23/2004.
> I use the command shp2pgsql to pass the information of the shapefile
> to postgres table.
> MapFile
>  LAYER
>     NAME 'chile_comuna'
>     TYPE POLYGON
>     #DATA 'chile_comuna.shp'
>     CONNECTIONTYPE postgis
>   CONNECTION "user=postgres password=1234 dbname=geo_referencia
> host=localhost"
>   DATA "the_geom from chile_comuna"
> can anyone help me? pleasee...
> rgs
> mapserver-users at lists.osgeo.org
Alexandre Dubé
Mapgears
www.mapgears.com
