[mapserver-users] MapServer on Intel Atom?
Milo van der Linden mlinden at zeelandnet.nl
Tue Jan 13 08:28:30 EST 2009
Just out of curiosity,
With what reason would you like to have a mapserver on a mobile device?
I assume mostly to have some sort of localhost connection from a local
application, and in that case, I would opt for a solution where one can
for instance download raster-tiles from a server to the mobile device
that are then used by the application through more simplified functions,
for vector the same procedure, download vectors and make them available
through libraries. Installing a httpserver with mapserver as a cgi app
sounds like a bit of overkill. Perhaps the mobile app can simply use
gdal and ogr libraries.
Dan Little wrote:
> I agree with where Jukka is going...  Raster layers are usually pretty fast so long as they are tuned correctly.
> ----- Original Message ----
>> From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>> To: kreshna_iceheart at yahoo.com; mapserver-users at lists.osgeo.org
>> Sent: Tuesday, January 13, 2009 6:04:07 AM
>> Subject: Re: [mapserver-users] MapServer on Intel Atom?
>> Hi,
>> You say that your raster layer is slower than vector layers, but do you feel it
>> is too slow?  Your image should be served pretty fast by Mapserver.  The key is
>> that tiff file is tiled (for zoom-in situation) and that it has overviews (for
>> zoom-out case). Could you send the gdalinfo report about your image if you
>> suffer from slowness?
>> -Jukka Rahkonen-
>>> -----Alkuperäinen viesti-----
>>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
>>> Lähetetty: 13. tammikuuta 2009 12:35
>>> Vastaanottaja: mapserver-users at lists.osgeo.org; Dan Little
>>> Aihe: Re: [mapserver-users] MapServer on Intel Atom?
>>> Hi, thanks.
>>> The vectors are quite simple. I've never experienced slow
>>> down when displayed vector data, not even on an old Toshiba
>>> M20 laptop.
>>> Raster, on the other hand, is always the biggest problem.
>>> Compared to polygons, my raster is always slower to zoom, to
>>> pan, etc (despite the size is only 500 Mb). Is displaying
>>> raster more CPU-intensive or memory-intensive? If I'm using
>>> Intel Atom, will my raster be affected severely?
>>> Also, can using bigger RAM (let say, 2GB or so) compensate
>>> for the lack of processing power of Intel Atom?
>>> Thanks again,
>>> -Kresh
>>> --- On Mon, 1/12/09, Dan Little wrote:
>>>> From: Dan Little
>>>> To: kreshna_iceheart at yahoo.com, mapserver-users at lists.osgeo.org
>>>> Date: Monday, January 12, 2009, 9:18 PM I think the atom
>>> will be more
>>>> than adequate... depending on the dataset. :-)
>>>> Serving 100 points is significantly less intensive than serving 100
>>>> city-boundary polygons.
>>>> (Oops forgot to send to the list)
>>>>> From: "kreshna_iceheart at yahoo.com"
>>>>> To: mapserver-users at lists.osgeo.org
>>>>> Sent: Monday, January 12, 2009 8:09:15 PM
>>>>> Subject: [mapserver-users] MapServer on Intel Atom?
>>>>> I'll be doing a lot of MapServer demo in the
>>>> future. I'm quite interested in
>>>>> Intel Atom-based subnotebooks for the purpose (like
>>>> Lenovo IdeaPad S10), since
>>>>> they are light and mobile.
>>>>> However, I wonder if Intel Atom is adequate to run
>>>> MapServer. The MapServer will
>>>>> be run on either ms4w on Windows XP, or directly on
>>>> Linux. The layers are stored
>>>>> on postGIS (there are fifteen layers or so), and there
>>>> is also a 476 megabytes
>>>>> raster file in .TIFF format.
>>>>> Will Intel Atom be adequate for the purpose? Will 2GB
>>>> of memory help? Has anyone
>>>>> ever done such thing before?
>>>>> Many thanks,
>>>>> -Kresh
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
