[mapserver-users] Mapserver queries for line layer
Steve Lime Steve.Lime at dnr.state.mn.us
Tue Jan 13 16:20:27 EST 2009
Here's an example that uses OpenLayers with a hover event to fire queries off to MapServer:
  http://www.dnr.state.mn.us/waters/csg/index_copy.html
The relevant javascript is at:
  http://maps.dnr.state.mn.us/waters/csg/current_test.js
When ever the user pauses the app fires a query off to MapServer. In this case I'm querying points
but the same code would work for lines. If the query fails (e.g. nothing found) I use the webObj
EMPTY parameter to return content that just contains a -1. If it succeeds, templated query results
are passed back and displayed. In this case I'm using an Ext.js window but you could just as easily
update a div or use another popup library.
Hope it helps...
Steve
>>> On 1/12/2009 at 4:01 AM, in message <496B1512.8000805 at gslab.com>, Subha
Ramakrishnan <subha at gslab.com> wrote:
> Hi All,
> I using Mapserver 5.0.2 and Openlayers. I had posted a query before on
> how to show pop up for a line layer.
> I am trying to use the mapserver queries for the same. I find
> documentation that uses a shapefile for the data and use variables from
> that on the template file. But all the data I've is in a postgresql DB.
> Can someone please give me an example as to how to query DB for the
> features' details and show it on the map as a pop up?
> And is there anything on Openlayers side that I've to do to enable this
> mapserver queries?( like sending a request to fetch a map)
> Thanks a lot for the help.
> Regards,
> Subha
> mapserver-users at lists.osgeo.org
