[mapserver-users] MapServer on Intel Atom?
kreshna_iceheart at yahoo.com kreshna_iceheart at yahoo.com
Tue Jan 13 22:49:49 EST 2009
Hi Jukka, actually I'm quite surprised, because based on my experience, raster layer is always slower than vector layer regardless of system. I attached  the gdal info result with this mail.
And Milo, yes, I have both MapServer and browser running on my notebook. The browser accesses MapServer using localhost connection. I'm interested in your idea though. Do you mean I can create a web-based interactive map solely using ogr and gdal, without MapServer component? But how? Is it possible for a web application to interactively display .SHPs and .TIFFs without MapServer?
Or do you mean I have to stay connected to the internet (to access the remote MapServer) during my demo? Unfortunately, in most cases  I won't be able to connect to the internet during the demo.
Nonetheless, is MapServer more CPU-dependent or memory-dependent? How far large RAM can compensate for weak CPU like Intel Atom?
Thanks,
--- On Tue, 1/13/09, Milo van der Linden <mlinden at zeelandnet.nl> wrote:
> From: Milo van der Linden <mlinden at zeelandnet.nl>
> Subject: Re: [mapserver-users] MapServer on Intel Atom?
> To: mapserver-users at lists.osgeo.org
> Date: Tuesday, January 13, 2009, 8:30 AM
> Oops, sorry. Should have read the initial post, for
> demonstration purposes, using datasets that are not to big
> sounds possible to me.
> Dan Little wrote:
> > I agree with where Jukka is going...  Raster layers
> are usually pretty fast so long as they are tuned correctly.
> > ----- Original Message ----
> >> From: Rahkonen Jukka
> <Jukka.Rahkonen at mmmtike.fi>
> >> To: kreshna_iceheart at yahoo.com;
> >> Sent: Tuesday, January 13, 2009 6:04:07 AM
> Atom?
> >> Hi,
> >> You say that your raster layer is slower than
> vector layers, but do you feel it is too slow?  Your image
> should be served pretty fast by Mapserver.  The key is that
> tiff file is tiled (for zoom-in situation) and that it has
> overviews (for zoom-out case). Could you send the gdalinfo
> report about your image if you suffer from slowness?
> >> -Jukka Rahkonen-
> >>> -----Alkuperäinen viesti-----
> >>> Lähettäjä:
> mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> >>> Lähetetty: 13. tammikuuta 2009 12:35
> >>> Vastaanottaja:
> mapserver-users at lists.osgeo.org; Dan Little
> >>> Aihe: Re: [mapserver-users] MapServer on Intel
> Atom?
> >>> Hi, thanks.
> >>> The vectors are quite simple. I've never
> experienced slow down when displayed vector data, not even
> on an old Toshiba M20 laptop.
> >>> Raster, on the other hand, is always the
> biggest problem. Compared to polygons, my raster is always
> slower to zoom, to pan, etc (despite the size is only 500
> Mb). Is displaying raster more CPU-intensive or
> memory-intensive? If I'm using Intel Atom, will my
> raster be affected severely?
> >>> Also, can using bigger RAM (let say, 2GB or
> so) compensate for the lack of processing power of Intel
> Atom?
> >>> Thanks again,
> >>> -Kresh
> >>> --- On Mon, 1/12/09, Dan Little wrote:
> >>>> From: Dan Little Subject: Re:
> >>>> To: kreshna_iceheart at yahoo.com,
> >>>> Date: Monday, January 12, 2009, 9:18 PM I
> think the atom
> >>> will be more
> >>>> than adequate... depending on the dataset.
> >>>> Serving 100 points is significantly less
> intensive than serving 100 city-boundary polygons.
> >>>> (Oops forgot to send to the list)
> >>>>> From:
> "kreshna_iceheart at yahoo.com"
> >>>>>           To:
> >>>>> Sent: Monday, January 12, 2009 8:09:15
> PM
> >>>>> Subject: [mapserver-users] MapServer
> on Intel Atom?
> >>>>> I'll be doing a lot of MapServer
> demo in the
> >>>> future. I'm quite interested in
> >>>>> Intel Atom-based subnotebooks for the
> purpose (like
> >>>> Lenovo IdeaPad S10), since
> >>>>> they are light and mobile.
> >>>>> However, I wonder if Intel Atom is
> adequate to run
> >>>> MapServer. The MapServer will
> >>>>> be run on either ms4w on Windows XP,
> or directly on
> >>>> Linux. The layers are stored
> >>>>> on postGIS (there are fifteen layers
> or so), and there
> >>>> is also a 476 megabytes
> >>>>> raster file in .TIFF format.
> >>>>> Will Intel Atom be adequate for the
> purpose? Will 2GB
> >>>> of memory help? Has anyone
> >>>>> ever done such thing before?
> >>>>> Many thanks,
> >>>>> -Kresh
> >>>>> mapserver-users mailing list
> >> _______________________________________________
Driver: GTiff/GeoTIFF
Files: GABUNGAN.TIF
Size is 14307, 11632
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.2572235630016,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",111],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",10000000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","32749"]]
Origin = (572639.482510472650000,9112580.054120404600000)
Pixel Size = (0.552054792679273,-0.552054792679273)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  572639.483, 9112580.054) (111d39'33.11"E,  8d 1'39.77"S)
Lower Left  (  572639.483, 9106158.553) (111d39'33.44"E,  8d 5'8.86"S)
Upper Right (  580537.730, 9112580.054) (111d43'51.12"E,  8d 1'39.33"S)
Lower Right (  580537.730, 9106158.553) (111d43'51.50"E,  8d 5'8.42"S)
Center      (  576588.606, 9109369.303) (111d41'42.29"E,  8d 3'24.10"S)
Band 1 Block=14307x1 Type=Byte, ColorInterp=Red
Band 2 Block=14307x1 Type=Byte, ColorInterp=Green
Band 3 Block=14307x1 Type=Byte, ColorInterp=Blue
