Re: [mapserver-users] Problems with sld´s polgonsymbolizer interpretation
Thilo Wehrmann thilo.wehrmann at dlr.de
Wed Jan 14 04:26:44 EST 2009
I could identify why my sld could not be interpreted but it doesn´t make
sense to me. The problem is that without the value in the ogc:Literal
context it worked like:
<sld:Fill>
<sld:CssParameter name="fill">#FFECBF</sld:CssParameter>
<sld:CssParameter name="fill-opacity">
<ogc:Literal>1</ogc:Literal>
</sld:CssParameter>
</sld:Fill>
instead of this one:
<sld:Fill>
<ogc:Literal>#FFECBF</ogc:Literal>
</sld:CssParameter>
</sld:CssParameter>
</sld:Fill>
And that was the reason why fonts are interpreted, too. There were no
ogc:Literal specifications used. For working purpose I can replace all the
ogc:Literal tag but I think this can be only a transitional solution.
Thilo Wehrmann
Thilo Wehrmann wrote:
>     hello together,
> sorry for possible double submission. Currently we work at the dynamic
> generation of wms service layers for our project data. For styling
> issues we use slds stored in exist database. The access to the sld works
> straight but we figure out some problems with line/polygonsymbolizer
> interpretation of the returned slds. For the raster data everything
> works fine but for all vector data the fill colours won´t be used
> (standard grey is used instead. Mapserver 5.2.1 uses the sld because
> changes of the font settings are recognized and correctly rendered.
> [SLDs deleted...]
> The compiled map file after sld interpretation says nothing about these
> settings and standard colours are used for painting. I read that there
> were some problems in earlier versions of mapserver concerning stroke
> colours...
> Does anybody know about this problem or knows a workaround? mapserver is
> quite an impressive piece of software.
> Thank you and best regards,
>  Thilo Wehrmann
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Problems-with-sld%C2%B4s-polgonsymbolizer-interpretation-tp2152137p2155896.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
