[mapserver-users] GPX format supported?
Fawcett, David
David.Fawcett at state.mn.us
Wed Jan 14 09:43:27 EST 2009
Bean,
Can you post your gpx file (or a sample file that demonstrates the
problem)?
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
bean at warbaby.com
Sent: Tuesday, January 13, 2009 6:20 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] GPX format supported?
Hi Jeff,
Thanks for the reply. I ran ogrinfo on both "waypoints" and
"track_points". "waypoints" returns 147 entries and "track_points"
returns 0 entries (there are no tracks recorded in my GPS unit at this
point, just trying to keep it simple for now). This is returned from a
Garmin eTrex Venture through gps babel.
Thanks for entering the SVN.
I am still puzzled about my mapfile layer however. It fails to
parse when CLASS is added and the layer fails to load when CLASS is
deleted. I feel sure my mapfile layer syntax is correct (although my
previous blooper with the errant END statement says I shouldn't be so
sure). Would you mind looking for obvious errors for the following?
LAYER
NAME 'GPS'
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
'/Applications/MAMP/d/DATA/NonGrassFiles/GPX/gpsbabel_output.gpx'
DATA 'waypoints'
STATUS ON
DEBUG 5
CLASS
STYLE
SYMBOL 'CIRCLE'
SIZE 3
OUTLINECOLOR 0 0 0
COLOR 106 7 182
END
END
END
Thanks,
bean
While testing gpx just now I realized that we don't have
a GPX page in the MapServer Vector Data Access doc, so I have added it
into SVN.
In my testing I was forced to use the "track_points"
feature, as there was no actual data in the "waypoints" feature (you can
test this through ogrinfo).
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090114/36b1ae99/attachment.html
