[mapserver-users] Problem in replacing Template parameter
via URL!!!
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Jan 14 10:34:50 EST 2009
The patterns are regexes so "^Cad" should work. The URL syntax also varies depending
on version. Pre-5.0 uses the syntax you mention. 5.0+ uses:
...&map_web=TEMPLATE+Cadatsre&...
Steve
>>> Saka Royban <srph124 at yahoo.com> 01/14/09 4:41 AM >>>
hi everyone.
i have some problem in replacing Template parameter via URL to alter the whole html template file.
I have tested both template=Cadatsre and map_web_template=Cadastre but no diffrence.
Although templatepattern is set to "Cad*"
anyone knows what is the problem. maybe i'm unaware of a particular configuration
Thanks in advance
