[mapserver-users] wms and maplab application error
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Jan 19 02:24:12 EST 2009
Maplab project is no more active. Latest Maplab works only with Mapserver 4.2 or 4.1 and with some older php version. If you are just learning Mapserver and applications built on it and you don't have any special interest towards Maplab I would recommend you to forget it and start learning some other, still active application framework. Start reading the list at http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#ms4w-applications.
Maplab was indeed quite a nice application. With it it was possible to made working interactive map applications without any programming in any language once there was a working mapfile available. I wonder if any of the living projects can offer as low threshold for new users.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta cemre yilmaz
Lähetetty: 19. tammikuuta 2009 0:01
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] wms and maplab application error
Hello everybody;
I am trying to apply an application about OGC Web Map services and SLD with UMN mapserver. I found an application on the web. I have already installed MS4W and then I have installed the maplab applicaiton on MS4W. My problem is that, there is a tutorial map file with the application and I need to edit it with MapLab. When I wrote in the browser http://localhost/maplab/ I can see the main page of the maplab but when I try to edit the tutorial map file there is an error aperaring and I can't be able to open the tutorial map file. The error is below;
Warning: dl(): Unable to load dynamic library '/ms4w/Apache/php/extensions/php_mapscript.dll' - Belirtilen modül bulunamadý. in C:\ms4w\apps\maplab-2.2.1\htdocs\mapedit\mapeditapp.php on line 150
Fatal error: Call to undefined function: ms_tokenizemap() in C:\ms4w\apps\maplab-2.2.1\htdocs\mapedit\mapeditapp.php on line 168
What should I do to open the map file. What is the problem?..
If you know about the error could you please inform me. It is very urgent for me.
Thanks..
Cemre Y.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090119/c1782e70/attachment.html
