[mapserver-users] mapObj.getlayersdrawingorder
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon Jan 19 10:25:15 EST 2009
Hi there,
You probably meant you did a call like this
$oMap->getLayersDrawingOrder(), which is the correct syntax to use in php ?
Quick test using ms4w 2.3.1 environment returns expected result:
<?php
dl('php_mapscript.dll');
$oMap = ms_newMapObj('f:/msapps/gmap-ms40/htdocs/gmap75.map');
print_r ($oMap->getLayersDrawingOrder());
Assefa
Balázs Bámer wrote:
> Hi All,
> I tried to call MapObj.getlayersdrawingorder() from PHP Mapscript
> (ms4w 2.3.1 with MapServer 5.2.1, PHP 5.2.6). PHP script terminates.
> Same result for MapObj.getLayersDrawingOrder() (the PDF description is
> ambiguous about these names).
> How it is called? Is it really usable? In the appropriate .dll file
> both names appear.
> thanx in advance: Balázs Bámer
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
