[mapserver-users] google tiles
Roger André randre at gmail.com
Mon Jan 19 12:02:52 EST 2009
Hi Chad,
I wasn't aware that "tile" is a valid mode of operation for Mapserver.  I
looked on http://mapserver.org/cgi/controls.html and didn't see it
referenced there, but its entirely possible that it exists and that I've
just missed it.  In any case, the way I'm familiar with generating google
map tiles is via the use of Tilecache.  Tilecache works as in intermediary
between Mapserver and your Google map. It make the appropriate request to
Mapserver for a tile, and then returns the tile to your map.  I think this
might be the solution you're looking for, http://tilecache.org/.
Best of luck,
Roger
On Mon, Jan 19, 2009 at 6:50 AM, Chad Clabaugh <cclabaugh at centwire.com>wrote:
>  Greetings,
> I have been trying to generate google tiles from shapefiles using
> mapserver.  I have been able to successfully generate maps by calling the
> url
> http://0.0.0.0/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage.map&mode=map. but when I attempt to use the url
> http://172.18.154.186/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage.map&mode=tile&tile=4+6+4
> I receive only empty images, regardless of tile specified.
> Thanks for any help!
> MAP
>   NAME COVERAGE
>   STATUS ON
>   SIZE 1400 900
>   EXTENT 639000.000000 4535300.000000 689900.000000 4582600.000000
>   UNITS METERS
>   SHAPEPATH "shapefiles"
>   IMAGECOLOR 220 220 220
>   IMAGETYPE PNG
>   PROJECTION
>     "init=epsg:4326"
>   END
>   LAYER
>     NAME CoverageMap
>     TYPE POLYGON
>     STATUS DEFAULT
>     DATA notforchad
>     CLASS
>       STYLE
>         OUTLINECOLOR 255 128 128
>         COLOR 225 0 0
>       END
>     END
>   END
> END
> Chad Clabaugh
> Technical Support, Engineering
> Office: 260.760.6398
> Mobile: 260.466.8861
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090119/1063ff9d/attachment.html
