[mapserver-users] google tiles
Roger André
randre at gmail.com
Mon Jan 19 21:43:24 EST 2009
Fascinating, thanks for sending the link! Since you state that you only get
blank images when you try it out, perhaps it is a projection mis-match? It
appears that your mapfile extents are defined in meters, which would match
spherical mercator, but your layer is in EPSG 4326. What if you make your
extents be in lat/lon instead?
Roger
On Mon, Jan 19, 2009 at 10:29 AM, Chad Clabaugh <cclabaugh at centwire.com>wrote:
> Thanks for your reply Roger. The spec for tilemode is at
> http://mapserver.org/output/tile_mode.html But I'll definitely look into
> TileCache as well.
> *From:* Roger André [mailto:randre at gmail.com]
> *Sent:* Monday, January 19, 2009 12:03 PM
> *To:* Chad Clabaugh
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] google tiles
> Hi Chad,
> I wasn't aware that "tile" is a valid mode of operation for Mapserver. I
> looked on http://mapserver.org/cgi/controls.html and didn't see it
> referenced there, but its entirely possible that it exists and that I've
> just missed it. In any case, the way I'm familiar with generating google
> map tiles is via the use of Tilecache. Tilecache works as in intermediary
> between Mapserver and your Google map. It make the appropriate request to
> Mapserver for a tile, and then returns the tile to your map. I think this
> might be the solution you're looking for, http://tilecache.org/.
> Best of luck,
> Roger
> On Mon, Jan 19, 2009 at 6:50 AM, Chad Clabaugh <cclabaugh at centwire.com>
> wrote:
> Greetings,
> I have been trying to generate google tiles from shapefiles using
> mapserver. I have been able to successfully generate maps by calling the
> url
> http://0.0.0.0/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage.map&mode=map. but when I attempt to use the url
> http://172.18.154.186/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/coverage.map&mode=tile&tile=4+6+4
> I receive only empty images, regardless of tile specified.
> Thanks for any help!
> MAP
> NAME COVERAGE
> STATUS ON
> SIZE 1400 900
> EXTENT 639000.000000 4535300.000000 689900.000000 4582600.000000
> UNITS METERS
> SHAPEPATH "shapefiles"
> IMAGECOLOR 220 220 220
> IMAGETYPE PNG
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME CoverageMap
> TYPE POLYGON
> STATUS DEFAULT
> DATA notforchad
> CLASS
> STYLE
> OUTLINECOLOR 255 128 128
> COLOR 225 0 0
> END
> END
> END
> END
> Chad Clabaugh
> Technical Support, Engineering
> Office: 260.760.6398
> Mobile: 260.466.8861
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090119/d57a104e/attachment-0001.html
