[mapserver-users] PHP Mapscript question
Dan Little danlittle at yahoo.com
Tue Jan 20 09:37:24 EST 2009
I think you'll need to clarify a little bit more.  Mapscript is a library you use inside of a PHP script.  If you're trying to access data on another server then you'll need to be more specific about what that data might be.  If you're trying to retrieve an image from another server then you might want to look into php curl.
----- Original Message ----
> From: rafael <rafaelchacon at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Sent: Tuesday, January 20, 2009 8:16:02 AM
> Subject: [mapserver-users] PHP Mapscript question
> Sorry If shouldn't  post php mapscript questions here. But I have I doubt and
> didn't find a mapscript forum. So the question is the following. How do I
> set the mapserver information in PHP Mapscript?? What happen if my mapserver
> is running in other machine and I want to connect to that server from
> another host where I'm developing the web application???
> Thanks in advance.
> Rafael
> http://n2.nabble.com/PHP-Mapscript-question-tp2186664p2186664.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
