[mapserver-users] RE: mapserver-users Digest, Vol 12, Issue 73
Tue Jan 20 10:38:05 EST 2009
Chad Clabaugh wrote:
> Am I not specifying my projection by using "init=epsg:4326" within the
> PROJECTION BLOCK????  I have tried as many different projections as I can
> find. Including 4326, 900913, 3785, and the following block...
Chad,
You need to specify a PROJECTION block on your LAYER *as well as*
on your MAP object. If everything is in the same coordinate system
then they can match.  Your sample map (fragment?) only had a
projection declaration on the map.
Best regards,
> Message: 3
> Date: Mon, 19 Jan 2009 20:16:28 -0800
> From: "Paul Ramsey" <pramsey at cleverelephant.ca>
> You need to specify the PROJECTION of your LAYER.
> P.
>> MAP
>>   NAME COVERAGE
>>   STATUS ON
>>   SIZE 1400 900
>>   EXTENT 639000.000000 4535300.000000 689900.000000 4582600.000000
>>   UNITS METERS
>>   SHAPEPATH "shapefiles"
>>   IMAGECOLOR 220 220 220
>>   IMAGETYPE PNG
>>   PROJECTION
>>     "init=epsg:4326"
>>   END
>>   LAYER
>>     NAME CoverageMap
>>     TYPE POLYGON
>>     STATUS DEFAULT
>>     DATA notforchad
>>     CLASS
>>       STYLE
>>         OUTLINECOLOR 255 128 128
>>         COLOR 225 0 0
>>       END
>>     END
>>   END
>> END
