[mapserver-users] optimal path between two points.
Valeria Muñoz
valemunoz at gmail.com
Tue Jan 20 13:57:48 EST 2009
Hi Stephen
thanks for the tip... I read the example and implements it with my data.
Now my problem is :how to rescue the data for instructions,distance,time
etc? ..
how can I know whether to turn right or left?
RG.
2009/1/20 Stephen Woodbridge <woodbri at swoodbridge.com>
> Valeria,
> You should really look at the example provided with:
> http://pgrouting.postlbs.org/wiki/WorkshopFOSS4G2007
> This is what I started with and then made my own modifications. The above
> workshop should walk you through how to setup a pgRouting without my
> additional hacks which will only confuse you at the moment.
> My dd_routing.php is a modified version of ax_routing.php that is included
> in the tutorial tarball.
> You might also want to read some of these pages if you have not already:
> http://www.google.com/search?hl=en&q=pgRouting&btnG=Google+Search
> Best regards,
> -Steve W
> Valeria Muñoz wrote:
>> hi Stephen.. thank for the tips...
>> I have reviewed the code but can only see the dd.html. can you send me the
>> dd_routing.php? .
>> please
>> thanks for everything
>> 2009/1/19 Stephen Woodbridge <woodbri at swoodbridge.com <mailto:
>> woodbri at swoodbridge.com>>
>> frank
>> thanks for the tips. I use prRouting and create the table
>> dijsktra_result. Now how can I implement with my mapfile? , how
>> deliver the data .. have some sample code?
>> thanks for your help.
>> 2009/1/19 Frank Warmerdam <warmerdam at pobox.com
>> <mailto:warmerdam at pobox.com> <mailto:warmerdam at pobox.com
>> <mailto:warmerdam at pobox.com>>>
>> Hi
>> I would like to implement the service "optimum path
>> between 2
>> points," can someone help me to be able to implement it?.
>> The
>> general idea is that a user picks a point A and point B and
>> a
>> display on the map the best route to get from point A to B.
>> Valeria,
>> MapServer itself does not do route calculation. You might
>> find some
>> useful pointers on this page:
>> http://wiki.osgeo.org/wiki/OpenRouter
>> I think the pgRouting (built on postgres/postgis) is the best
>> bet for
>> integration with MapServer.
>> So you have various options depending on the client software you are
>> using. So here are some ideas for you:
>> 1) put the route into a results table with a unique id, and pass the
>> unique id back to the client where it can then request the route
>> image via a mapserver mapfile the connects to the postgis database
>> and requests the layer be drawn with the unique id to select the
>> appropriate route.
>> 2) make an ajax request to generate the route and return the
>> polyline as an xml or json object back to the client. The client
>> then parses the result document and displays the route over the map.
>> 3) if you use OpenLayers for the client then you can use it to help
>> you do 1) as an image, or 1) as a wfs layer, or 2) as a vector layer.
>> You can look at the source for my demo page
>> http://imaptools.com/leaddog/routing/dd.html which does this with a
>> modified version of pgRouting (pgRouting does not return
>> turn-by-turn directions), but you should be able to modify my code
>> to work with pgRouting. I wrote a simple php script to proxy the
>> route request into postgres and to format the results back to the
>> client.
>> Look this over and see how far you can get with this. If you get
>> stuck, ask and I'm sure we can get you moving in the right direction.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090120/543c0a03/attachment.html
