[mapserver-users] Help needed on rendering large shp file on mapserver
KBlade hiicharles at gmail.com
Wed Jan 21 04:42:14 EST 2009
I would like to add more
- After reconstruct the map file from zero, I found that the error was
caused by LABEL.
- I have many road with name. MapServer take lots of time to display the
road label.
- When I filter the label using CLASSITEM and EXPRESSION, I manage to
display it.
Is there any way to display all the road label?
KBlade wrote:
> I have a shp file of size 10894 KB.
> The ms4w that I setup fail to display it in the browser.
> I was trying to output it as png pc256.
> The test was done localhost.
> When I try on smaller shp file, 85kb it will show me the map.
> Of course, I didn't use any client (eg. openlayers) to retrieve the raster
> in tiles.
> Please advise on this matter.
> Thanks.
> Symptons:
> CPU process running high when I try to retrieve the map from browser.
> It run like 10 - 20 mins then show:
> Internal Server Error
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator, admin at local.domain and inform
> them of the time the error occurred, and anything you might have done that
> may have caused the error.
> More information about this error may be available in the server error
> log.
> I think the ms4w apache timeout.
View this message in context: http://n2.nabble.com/Help-needed-on-rendering-large-shp-file-on-mapserver-tp2185617p2191329.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
