[mapserver-users] dynamically added shapes and their values
Dan Little
danlittle at yahoo.com
Wed Jan 21 16:09:06 EST 2009
Totally spit balling...
What about writing your layer to a temp. file that's KML/GML.
The file size is small, it carries the attributes you want, and it's easy to write the file using anything that writes text files (presumable C# can write text files ... but I know Microsoft misses little details from time to time).
Then write yourself a little mapfile you can open... maybe following this as a guide...
http://mapserver.org/input/vector/gml.html
-or-
http://mapserver.org/input/vector/kml.html
And just change "CONNECTION" using Mapscript to whatever the location of your newly created KML/GML file happens to be, then proceed with the processing.
----- Original Message ----
> From: Steve Lime <Steve.Lime at dnr.state.mn.us>
> To: Pietro Giannini <pgiannini at bytewise.it>; mapserver-users at lists.osgeo.org
> Sent: Wednesday, January 21, 2009 2:43:31 PM
> Subject: Re: [mapserver-users] dynamically added shapes and their values
> PG: At this point inline feature can carry no attributes and as a result cannot
> be
> classified. So I don't think you're going to be able to make this work. The work
> around is to use separate layers for what would have been a class and add
> features to the appropriate layer.
> Steve
> >>> On 1/21/2009 at 10:29 AM, in message
> <55312.89.97.235.106.1232555376.squirrel at localhost.localdomain>, "Pietro
> Giannini" wrote:
> > Hi all,
> > I'm working to a c# asp.net project embedding a mapscript application.
> > My attempt is to add dynamically features to a layer object and classify
> > them in different colors.
> > The features are INLINE features: I don't add the features to the source
> > of the layer.
> > I'm able to create different classes and styles in the layer, set a field
> > as classitem and set an EXPRESSION string to the class.
> > I found the
> > shapeObj.initValues(numOfFields)
> > method, which cannot set the field names, only the number, and also the
> > shapeObj.setValue(indexOfField, valueAsString)
> > for setting the value.
> > Now I need a field name to set a CLASSITEM property of the layer!!!
> > I found no methods to add a named field to the layer.
> > Maybe I follow a wrong way...
> > Someone has an idea?
> > thanks in advance
> > ...........................pg
