[mapserver-users] Mapserver Hardware Specifications?
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Jan 22 12:20:52 EST 2009
MapServer tends to be IO bound so this should work nicely.
Steve
>>> On 1/22/2009 at 2:25 AM, in message <49782D97.2050307 at gmail.com>, Doug White
<doug.royce.white at gmail.com> wrote:
> Hi,
> Is anyone running mapserver in a stable production or development
> environment on dedicated hardware?
> If so, I'd be interest to know the server specifications you are using.
> As part of FOSS4G2009 it is intended to showcase mapserver along with
> other open source software. Currently the following hardware specs are
> proposed...
> 512GB Disk Raid0
> 4 GB RAM
> 2x Dual Core CPU
> Would anyone recommend a higher specification? Keeping in mind this will
> be used to showcase the potential of mapserver.
> Regards,
> Doug White.
> mapserver-users at lists.osgeo.org
