[mapserver-users] Mapscript won't load after PHP update
Dominik Schmid
dominik.schmid at ilu.ch
Fri Jan 23 03:46:27 EST 2009
Thanks, Daniel for the quick reply. I did make sure that php-devel is
also up-to-date (even checked the /usr/include/php directory manually if
it had been updated). I did the update on the test machine so I can
cross check with the productive server for differences. One thing I
notice is, that phpinfo() on the test server doesn't list the Mapscript
module anymore as it does on the productive server. We installed the
older version of PHP (5.1.6) also using yum. Mapserver is configured
with the following options:
--with-ogr \
--with-proj \
--with-geos=/usr/bin/geos-config \
--with-gdal \
--with-postgis=/usr/bin/pg_config \
--with-httpd=/usr/sbin/httpd \
--with-php=/usr/include/php \
--with-wfs \
--with-wfsclient \
--with-wmsclient \
--enable-debug \
--with-threads \
--with-wcs \
--with-wcsclient \
--with-sos \
--with-gd \
--with-freetype=/usr/bin \
--with-jpeg \
--with-agg=/srv/software/agg-2.5
Could it be the case that I need to recompile PHP to use the same
Mapscript version as Mapserver? I don't see any configure option on the
old (5.1.6.) PHP version indicating this.
Dominik
Daniel Morissette wrote:
> Dominik Schmid wrote:
>> PHP Warning: dl() [<a href='function.dl'>function.dl</a>]: MapScript:
>> Unable to initialize module
>> Module compiled with module API=20050922, debug=0, thread-safety=0
>> PHP compiled with module API=20060613, debug=0, thread-safety=0
>> These options need to match in ......
>> I made double sure that I compiled against the correct (new) version
>> of PHP so that can't be the issue here. I have not found any
>> information as to what else I can check or as to what else I could be
>> doing wrong so I need to ask here.
> There is not much else to check. This error really tells you that the
> php_mapscript.so you are loading was compiled for the wrong version of PHP.
> Sounds like you need to make triple sure that you have installed and are
> compiling against the correct set of php-devel files: yum install the
> php-devel package for the right version of php and make sure you
> uninstall any previous version.
> If that doesn't solve your problem then perhaps try sharing your
> MapServer configure options with us on the list...
> Daniel
Dominik Schmid
Dipl. Umweltnaturwissenschafter ETH
ilu AG
Zentralstrasse 2a
CH-8610 Uster
Tel: +41 44 / 944 55 56 (Direktwahl)
Tel: +41 44 / 944 55 55 (allgemein)
Fax: +41 44 / 944 55 66
mailto:dominik.schmid at ilu.ch
http://www.ilu.ch
