[mapserver-users] OGR problem connecting to mdb using ovf
Dejan.Gambin at pula.hr
Tue Jan 27 10:23:16 EST 2009
I need to connect to Access database that has (among the other columns)
spatial data in two columns named "x coord" and "y coord". I am trying to
implement Virtual Spatial Data according to
http://www.mapserver.org/input/vector/VirtualSpatialData.html.
I have made ovf file like this:
<OGRVRTDataSource>
<OGRVRTLayer name="krk">
<SrcDataSource>ODBC:@Krk</SrcDataSource>
<SrcLayer>baza</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="x koord" y="y
koord"/>
</OGRVRTLayer>
</OGRVRTDataSource>
and map file layer like this (using p.mapper):
LAYER # kc
CONNECTION "krk.ovf"
CONNECTIONTYPE OGR
NAME "krk"
DATA "krk"
STATUS ON
TYPE POINT
METADATA
"DESCRIPTION" "KC"
"LAYER_ENCODING" "WINDOWS-1250"
END # Metadata
CLASS
Name 'Kc broj'
COLOR 0 0 0
SYMBOL 'circle'
SIZE 10
TEMPLATE void
END # Class
END
I have also made use and system dsn connection named "krk".
Testing with ogrinfo works fine, for example:
C:\Projekti\GIS\WebGIS\podaci\krk>ogrinfo krk.ovf krk|more
ERROR 4: Update access not supported for VRT datasources.
Had to open data source read-only.
INFO: Open of `krk.ovf'
using driver `VRT' successful.
Layer name: krk
Geometry: Point
Feature Count: 2
Extent: (5000450.000000, 4997536.000000) - (5196390.000000,
5000300.000000)
Layer SRS WKT:
But trying to run on web I am getting internal server error: CGI/FastCGI
has encountered a problem and needs to close...". Also, my php error log
file says:
[27-Jan-2009 16:21:45] PHP Warning: [MapServer Error]: msOGRFileOpen():
Open failed for OGR connection
`C:/Projekti/GIS/WebGIS/podaci/krk/krk.ovf'.
Unable to initialize ODBC connection to DSN for @Krk,
[Microsoft][ODBC Driver Manager] Driver's SQLSetConnectAttr failed
in C:\ms4w\apps\pmapper\pmapper-3.2.0\incphp\initgroups.php on line 239
[27-Jan-2009 16:21:45] PHP Stack trace:
[27-Jan-2009 16:21:45] PHP 1. {main}()
C:\ms4w\apps\pmapper\pmapper-3.2.0\map.phtml:0
[27-Jan-2009 16:21:45] PHP 2. include_once()
C:\ms4w\apps\pmapper\pmapper-3.2.0\map.phtml:51
[27-Jan-2009 16:21:45] PHP 3. Init_map->initAllParameters()
C:\ms4w\apps\pmapper\pmapper-3.2.0\incphp\init\init.php:34
[27-Jan-2009 16:21:45] PHP 4. Init_map->_initGroups()
C:\ms4w\apps\pmapper\pmapper-3.2.0\incphp\init\initmap.php:60
[27-Jan-2009 16:21:45] PHP 5. Init_groups->Init_groups()
C:\ms4w\apps\pmapper\pmapper-3.2.0\incphp\init\initmap.php:292
[27-Jan-2009 16:21:45] PHP 6. Init_groups->_createGroups()
C:\ms4w\apps\pmapper\pmapper-3.2.0\incphp\initgroups.php:48
[27-Jan-2009 16:21:45] PHP 7. Init_groups->_initResultFields()
C:\ms4w\apps\pmapper\pmapper-3.2.0\incphp\initgroups.php:117
[27-Jan-2009 16:21:45] PHP 8. ms_layer_obj->open()
C:\ms4w\apps\pmapper\pmapper-3.2.0\incphp\initgroups.php:239
Any help would be greatly appreciated
Thanks very much
regards, dejan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090127/671ecff0/attachment-0001.html
