AW: [mapserver-users] problem with scientific notation in WFS field output
Eichner, Andreas - SID-NLKM Andreas.Eichner at sid.sachsen.de
Thu Jan 29 02:11:49 EST 2009
a quick and dirty solution might be altering the field type to be a
character string since the format you are using allows comparision
operators to work as expected, for example "19990112" is literally less
than "20010822". Also, exporting as character strings would fix your
display format. I don't know if MS can dynamically cast the value in
case arithmetic operations are involved. So this solution might or might
not work for you.
