[mapserver-users] querybypoint a postgis db with php mapscript
MirMatin
mirmatin at gmail.com
Fri Jan 30 06:53:27 EST 2009
Hi Stefan,
Did you get a work out of the problem. I am having the same problem and want
to find some solution.
Looking forward to your response
Regards,
Mir Matin
Stefan Schwarzer wrote:
> Hi there,
> I guess there is something I am doing wrong. I think that since I
> moved from shapefiles to postgis, my query (bypoint/byrect) doesn't
> work anymore. Is there anything I have to change? I am kind of
> frustrated, because if looked around everywhere to find the problem;
> this issue has cost me hours over hours, but nothing in sight
> My code looks like this:
> //Set the layers status ON (b/c it might not be...)
> $Layer -> set("status", 1);
> $ImgWidth = $map -> width;
> $ImgHeight = $map -> height;
> $x = (($ptX / $ImgWidth) * ($ext3 - $ext1)) + $ext1;
> $y = $ext4 - (($ptY / $ImgHeight) * ($ext4 - $ext2));
> $x1 = (($extent_px0 / $ImgWidth) * ($ext3 - $ext1)) + $ext1;
> $y1 = $ext4 - (($extent_px1 / $ImgHeight) * ($ext4 - $ext2));
> $x2 = (($extent_px2 / $ImgWidth) * ($ext3 - $ext1)) + $ext1;
> $y2 = $ext4 - (($extent_px3 / $ImgHeight) * ($ext4 - $ext2));
> $click_pt = ms_newPointObj();
> $click_pt -> setXY($x, $y);
> $click_rt = ms_newRectObj();
> $click_rt -> setextent($x1, $y2, $x2, $y1);
> //Query the Map at the point clicked
> if (!$imgbox)
> $a = $map -> queryByPoint($click_pt, MS_MULTIPLE, -1);
> else
> $a = $map -> queryByRect($click_rt);
> And my mapfile like this:
> LAYER
> NAME floods_killed
> STATUS ON
> CONNECTIONTYPE postgis
> CONNECTION 'user=xxx password=xxx dbname=xxxx'
> TYPE POLYGON
> DATA "the_geom FROM
> SELECT
> c.the_geom,
> c.name,
> COALESCE(d.value, -9999) AS value,
> d.id_country AS uid
> FROM
> floods_killed AS d
> RIGHT JOIN
> countries AS c ON c.id = d.id_country
> WHERE
> d.year_start = 2007 AND
> c.id = d.id_country
> ) AS foo USING UNIQUE uid USING srid=4326"
> LABELITEM value
> CLASSITEM 'value'
> CLASS
> NAME ''
> EXPRESSION ([value]=-10001)
> TEMPLATE 'empty space'
> END # CLASS
> CLASS
> NAME 'Units: Number of People'
> EXPRESSION ([value]=-110003)
> TEMPLATE 'units as title in legend'
> END # CLASS
> Thanks for any hints!
> Stef
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/querybypoint-a-postgis-db-with-php-mapscript-tp1971499p2244449.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
