[mapserver-users] Problem with transparency overlays
Alexandre Dube
adube at mapgears.com
Fri Jan 30 08:31:02 EST 2009
Hi Rafael,
Here's what the doc has to say about the TRANSPARENT option in the MAP
object :
TRANSPARENT [on|off]
Use FORMATOPTION “TRANSPARENT=ON” in the /OUTPUTFORMAT/
<http://mapserver.org/mapfile/outputformat.html#outputformat>
declaration to specify if the output images should be transparent.
Deprecated since version 4.6.
So you should use OUTPUTFORMAT, for example like this :
OUTPUTFORMAT
NAME "agg"
MIMETYPE "image/png"
DRIVER AGG/PNG
EXTENSION "png"
IMAGEMODE RGBA
TRANSPARENT ON
FORMATOPTION "INTERLACE=OFF"
END
(the above example uses the AGG driver)
Then, in your Openlayers layer's definition, use this param :
roads = new OpenLayers.Layer.MapServer( "Roads",
"http://192.168.1.100/cgi-bin/mapserv?map=us_states.map",
{layers: 'us_roads', map_imagetype: 'agg'}, {isBaseLayer:false});
The "transparent" option has no effects on a Layer.MapServer. It would
have on a Layer.WMS though.
Be sure to look at the OUTPUTFORMAT documentation to pick the right
image type you want to use.
Hope this helps,
Alexandre
Rafael chacón wrote:
> Hi, I'm having some trouble with transparency layers appear/disappear.
> I'm working with MapServer and Openlayers... I want two layers to
> overlay but when I choose to show one the other one hides... Here is
> some of my code.... Thanks for the help :)
> Mapserver File:
> MAP
> size 800 600
> imagetype 'gif'
> TRANSPARENT ON
> imagecolor 0 0 255
> extent -180 -90 180 90
> SYMBOLSET "symbols"
> PROJECTION
> "init=epsg:4269"
> END
> WEB
> IMAGEPATH "/var/www/apache2-default/gis_tests/tmp/"
> IMAGEURL "/apache2-default/gis_tests/tmp/"
> TEMPLATE "empty.html"
> metadata
> wms_title "us_states"
> wms_srs "EPSG:4269"
> end
> end
> _______
> OPenlayers:
> layer = new OpenLayers.Layer.MapServer( "Estados unidos",
> {layers: 'us_states', 'format':'image/png'});
> {layers: 'us_roads',transparent: 'true', 'format':'image/png'},
> gps = new OpenLayers.Layer.MapServer( "GPS",
> {layers: 'gps_points', transparent: 'true', 'format':'image/png' },
> roads.setVisibility(false);
> gps.setVisibility(false);
> Rafael Chacon,
> "El hombre es la medida de todas las cosas". Protagoras
> mapserver-users at lists.osgeo.org
Alexandre Dubé
Mapgears
www.mapgears.com
