[mapserver-users] label FOLLOW and OFFSET
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jan 31 15:55:16 EST 2009
Sorry Tim,
OFFSET is not support with ANGLE FOLLOW
-Steve W
Tim Norris wrote:
> Hi all,
> I have been playing with the FOLLOW label directive. What I am trying to
> achieve is a label that follows the street that is also OFFSET so that
> the label does not land on the line for the street, but instead 'above'
> it. Below is the LABEL directives that I am using, but note that I have
> also tried using the POSITION UC as well as the OFFSET 0 -6, but both
> give the same results. Please see the attached JPG image, you can see
> that 'M PARDO' is correct but that 'JR JUNIN' is not.
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> TYPE TRUETYPE
> FONT ArialBold
> SIZE 7
> ANTIALIAS TRUE
> ANGLE FOLLOW
> PARTIALS FALSE
> MINFEATURESIZE 40
> MINDISTANCE 50
> OFFSET 0 -6
> BUFFER 7
> END
> Any ideas as to why this is not working? I took a quick look in
> maplabel.c, but could not see anything obvious . . .
> thanks
> tim
> Tim Norris
> mapserver-users at lists.osgeo.org
