[mapserver-users] LABEL_NO_CLIP seems not working inmapserver 5.4.1
Rodriguez, Heraldo hrodriguez at siscat.com.ar
Wed Jul 1 08:29:17 EDT 2009
Thank you very much. I am afraid I am not allowed to upload any data ( the map would  be fine , but without the data I think it'll be useless).
   Anyway, I made the metatile larger (from 5x5 to 6x6) and now the map looks acceptable (some minimal duplication still persists, though.)
    Thanks a lot again.
Lic. Heraldo G. Rodriguez
  TEL: 54-11-4326-4002 int 255
  Dpto. Desarrollo
  Sistemas Catastrales S.A
-----Mensaje original-----
De: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
Enviado el: miércoles, 01 de julio de 2009 0:58
Para: mapserver-users at lists.osgeo.org; Rodriguez, Heraldo
Asunto: Re: [mapserver-users] LABEL_NO_CLIP seems not working inmapserver 5.4.1
Hi Rodriguez: I did a couple of quick tests and it seems like the directive is
working as intended, at least with some government unit boundary data. Any
chance you could put together a small test case? Perhaps converting some
data to shapefile and whipping up a simple mapfile that shows the problem.
Are others experiencing the same issues?
Steve
>>> "Rodriguez, Heraldo" <hrodriguez at siscat.com.ar> 06/30/09 10:33 AM >>>
Hi everyone,
              We have just upgraded from mapserver 5.2.0 to 5.4.1
Our application use OpenLayers, Tilecache with metatiles on, and
postgis.
The label positioning in polygons has improved a lot but now we are
experiencing  label duplication on metatile boundaries.
The layer with the issues is parcelas. We are using
labelcache_map_edge_buffer and LABEL_NO_CLIP=ON .
Has anyone an idea why  this is happening? The labels length varies from
2 to 4 characters maximum .
A fragment of our map is the following
WEB
    	#	TEMPLATE "set in index.html"
    	#	MINscale 1000
    		MAXscaleDENOM 1550000
		METADATA
			"wms_title"			...
			"wfs_title"			...
			"wms_onlineresource" ...
			"wfs_onlineresource" ...
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
			"wms_srs"			...
			"wfs_srs"			...
			"wms_encoding"		...
			"labelcache_map_edge_buffer" "-10"
		END
    		IMAGEPATH "/tmp/mapserver/"
			IMAGEURL "/mapserver/"
END
LAYER
		NAME		parcelas
		METADATA
			"wms_title"		"parcelas"
			"wms_include_items" "all"
			"wms_group_title" "Geograficos"
			"wfs_title"		"parcelas"
			"gml_include_items" "all"
			"gml_featureid" "gid"
		END
		CONNECTION  "user=xxxxx password=xxxxxx dbname=scgis
host=localhost port=5432"
		CONNECTIONTYPE  postgis
		PROCESSING "CLOSE_CONNECTION=DEFER"
		 PROCESSING "LABEL_NO_CLIP=ON"
		DATA		"the_geom FROM parcelas USING UNIQUE
gid"
		STATUS		DEFAULT
		TYPE		POLYGON
		OPACITY   80
		MAXscaledenom	15000
		LABELITEM 	parcela
		LabelMaxscaledenom 1200
		DUMP true
		CLASS
			NAME		"parcelas"
			TEMPLATE './QueryTemplates/parcelas.html'
			STYLE
				COLOR			242 239 233 #g
earth
				OUTLINECOLOR	210 210 210
			END
			Label
				minsize 7
				Size	7
				maxsize 8
				type	truetype
				PARTIALS false
				POSITION AUTO
				MINDISTANCE 	20
				PRIORITY     5
				font	"vera"
				color 	86 86 86
			end
		END
	END
Any help would be appreciated. Thanks in advance
Regards,
  Dpto. Desarrollo
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
